moron
Problem - Dziwne Pady Serwera
witam
ostatnio serwer sie zawiesza :/
dzieje sie tak po przeniesieniu dyskow do innej plyty z innym prockiem (Celeron 3.0 D => Pentium D 3.4)
nowa plyta to ASRock 775i65G (chipset Intel 865G)
migracja przeszla niby bez problemu ale serwer w ciagu 2 dni sie 3 razy zawiesil :/
w logach nic takiego nie ma - jedyne co dziwnego znalazlem daje ponizej
moze ktos to przetlumaczyc na ludzki jezyk? :)
Feb 24 05:31:38 s102240 kernel: ata2: command 0xc8 timeout, stat 0x50 host_stat 0x21
Feb 24 05:31:38 s102240 kernel: ata2: status=0x50 { DriveReady SeekComplete }
Feb 24 05:31:38 s102240 kernel: ata2: error=0x01 { AddrMarkNotFound }
Feb 24 05:31:38 s102240 kernel: Info fld=0x1, Current sdb: sense key No Sense
Feb 24 05:31:39 s102240 kernel: ata1: command 0xc8 timeout, stat 0x50 host_stat 0x21
Feb 24 05:31:39 s102240 kernel: ata1: status=0x50 { DriveReady SeekComplete }
Feb 24 05:31:39 s102240 kernel: ata1: error=0x01 { AddrMarkNotFound }
Feb 24 05:31:39 s102240 kernel: Info fld=0x1, Current sda: sense key No Sense
Feb 24 06:30:36 s102240 kernel: ata2: command 0xca timeout, stat 0x50 host_stat 0x21
Feb 24 06:30:36 s102240 kernel: ata2: status=0x50 { DriveReady SeekComplete }
Feb 24 06:30:36 s102240 kernel: ata2: error=0x01 { AddrMarkNotFound }
Feb 24 06:30:36 s102240 kernel: Info fld=0x1, Current sdb: sense key No Sense
Feb 24 06:30:41 s102240 kernel: ata1: command 0xc8 timeout, stat 0x50 host_stat 0x21
Feb 24 06:30:41 s102240 kernel: ata1: status=0x50 { DriveReady SeekComplete }
Feb 24 06:30:41 s102240 kernel: ata1: error=0x01 { AddrMarkNotFound }
Feb 24 06:30:41 s102240 kernel: Info fld=0x1, Current sda: sense key No Sense
Feb 24 13:57:00 s102240 kernel: ata2: command 0xc8 timeout, stat 0x50 host_stat 0x21
Feb 24 13:57:00 s102240 kernel: ata2: status=0x50 { DriveReady SeekComplete }
Feb 24 13:57:00 s102240 kernel: ata2: error=0x01 { AddrMarkNotFound }
Feb 24 13:57:00 s102240 kernel: Info fld=0x1, Current sdb: sense key No Sense
Feb 24 13:57:00 s102240 kernel: ata1: command 0xc8 timeout, stat 0x50 host_stat 0x21
Feb 24 13:57:00 s102240 kernel: ata1: status=0x50 { DriveReady SeekComplete }
Feb 24 13:57:00 s102240 kernel: ata1: error=0x01 { AddrMarkNotFound }
Feb 24 13:57:00 s102240 kernel: Info fld=0x1, Current sda: sense key No Sens
ps. dyski dzisiaj byly przeskanowane - sa ok
psx. mam mirror na 2x80GB SATA
A kernel przekompilowałeś pod nowy konfig, czy na żywca bez żadnych zmian odpaliłeś system? Swoją drogą, serwer na AsRocku. Mniam :).
powiedzieli ze powinien chodzic... :/
nowe jajko bedzie jutro rano
na razie udalo mi sie namowic 2 procki na wspolprace (wczesniej byly zwiechy i musialem jeden wylaczyc...)
Gość patrick
Prawdziwie serwerową i firmową płytę Ci dali ... ehh
