user1
Named Has Failed, Named Is Not Running
Powstał jakiś dziwny problem z named, oto info przy restarcie DNS:
named has failed, please contact the sysadmin (result was "named is not running"). Feb 17 15:51:19 XYZ named: failed Feb 17 15:51:20 XYZ named[11890]: starting BIND 9.2.4 -u named Feb 17 15:51:20 XYZ named[11890]: using 2 CPUs Feb 17 15:51:20 XYZ named[11890]: loading configuration from '/etc/named.conf' Feb 17 15:51:20 XYZ named[11890]: listening on IPv4 interface lo, 127.0.0.1#53 Feb 17 15:51:20 XYZ named[11890]: listening on IPv4 interface eth0, XX.XXX.XX.234#53 Feb 17 15:51:20 XYZ named[11890]: listening on IPv4 interface eth0:0, XX.XXX.XX.235#53 Feb 17 15:51:20 XYZ named[11890]: listening on IPv4 interface eth0:1, XX.XXX.XX.236#53 Feb 17 15:51:20 XYZ named[11890]: listening on IPv4 interface eth0:2, XX.XXX.XX.237#53 Feb 17 15:51:20 XYZ named[11890]: listening on IPv4 interface eth0:3, XX.XXX.XX.238#53 Feb 17 15:51:20 XYZ named[11890]: /etc/rndc.key:1: configuring key 'rndc-key': bad base64 encoding Feb 17 15:51:20 XYZ named[11890]: loading configuration: bad base64 encoding Feb 17 15:51:20 XYZ named[11890]: exiting (due to fatal error) Feb 17 15:51:20 XYZ named: uruchomienie named failed
sprawdzałem różne porady z wht.com ale nic nie pomogło.
Antyczny ten BIND, ale.. jeśli to CPanel (a tak mi się wydaje) to powinno starczyć /scripts/fixrndc.
Niestety
root@HOSTxyz [/]# /scripts/fixrndc
Uruchamianie named: [ZAWIÓDŁ]
po problemie
cp /etc/rndc.key /etc/rndc.key.old
rndc-confgen -a -b 128 -c /etc/rndc.key -k rndc-key
/etc/rndc.key service named restart
Topic do zamknięcia.
