Sebua 0 Zgłoś post Napisano Wrzesień 9, 2019 Witam, problem mam z odpaleniem JTS3ServerMod Web mianowicie: Error while starting Telnet interface on port 5873! 2019-09-09 18:53:36 START_MANAGER JTS3ServerMod 5.5.7 Hosting Edition (28.12.2015) Instance Manager started... 2019-09-09 18:53:36 CONFIG Bot chat command !exec is disabled! 2019-09-09 18:53:36 CONFIG Multi IP Mode disabled! 2019-09-09 18:53:36 LOGGER_SQL_CONNECT Successfully connected to MySQL server for logging! 2019-09-09 18:53:36 CONFIG MySQL mode enabled! 2019-09-09 18:53:36 TELNET_ERROR Error while starting Telnet interface on port 5873! 2019-09-09 18:53:36 JTS3ServerMod 5.5.7 Hosting Edition (28.12.2015): EXCEPTION java.net.BindException: Adres jest juĹĽ w uĹĽyciu (Bind failed) at java.net.PlainSocketImpl.socketBind(Native Method) at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:387) at java.net.ServerSocket.bind(ServerSocket.java:375) at java.net.ServerSocket.<init>(ServerSocket.java:237) at de.stefan1200.jts3servermod.InstanceManagerServer.run(InstanceManagerServer.java:123) 2019-09-09 18:53:36 SHUTDOWN Got signal from operating system or the last virtual bot instance was stopped, quitting now... 2019-09-09 18:53:36 STOP_ALL Stopping all virtual bot instances... 2019-09-09 18:53:36 QUIT_MANAGER Quit instance manager... Udostępnij ten post Link to postu Udostępnij na innych stronach
