DebekPL 0 Zgłoś post Napisano Kwiecień 6, 2017 Hej. Uczę się konfiguracji bind9. Zainstalowałem sobie maszynę na środowisku LAN VCenter w pracy. Co może być nie tak? [root@localhost named]# nslookup linux.local Server: 8.8.8.8 Address: 8.8.8.8#53 ** server can't find linux.local: NXDOMAIN Przerobiłem plik /etc/resolv.conf [root@localhost named]# cat /etc/resolv.conf # Generated by NetworkManager search linux.local nameserver 192.168.128.221 nameserver 8.8.8.8 nameserver 8.8.4.4 Mój hostname: [root@localhost named]# hostname localhost.localdomain123 PLIKI KONFIGURACYJNE: named.conf: options { listen-on port 53 { 127.0.0.1; 192.168.128.0; }; listen-on-v6 port 53 { ::1; }; directory "/var/named"; dump-file "/var/named/data/cache_dump.db"; statistics-file "/var/named/data/named_stats.txt"; memstatistics-file "/var/named/data/named_mem_stats.txt"; allow-query { any; }; allow-transfer {192.168.128.222; }; recursion yes; dnssec-enable yes; dnssec-validation yes; /* Path to ISC DLV key */ bindkeys-file "/etc/named.iscdlv.key"; managed-keys-directory "/var/named/dynamic"; pid-file "/run/named/named.pid"; session-keyfile "/run/named/session.key"; }; logging { channel default_debug { file "data/named.run"; severity dynamic; }; }; zone "." IN { type hint; file "named.ca"; }; include "/etc/named.rfc1912.zones"; include "/etc/named.root.key"; named.rfc1912.zones: zone "localhost.localdomain" IN { type master; file "named.localhost"; allow-update { none; }; }; zone "localhost" IN { type master; file "named.localhost"; allow-update { none; }; }; zone "1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa" IN { type master; file "named.loopback"; allow-update { none; }; }; zone "1.0.0.127.in-addr.arpa" IN { type master; file "named.loopback"; allow-update { none; }; }; zone "0.in-addr.arpa" IN { type master; file "named.empty"; allow-update { none; }; }; zone "linux.local" IN { type master; file "masters/linux.zone"; allow-update { none; }; }; zone "192.168.in-addr.arpa" IN { type master; file "masters/linux.rev"; allow-update { none; }; }; linux.zone $TTL 1D @ IN SOA ns1.linux.local. root.linux.local. ( 130915 ; serial 1D ; refresh 1H ; retry 1W ; expire 3H ) ; minimum IN NS ns1.linux.local. IN NS ns2.linux.local. IN MX 10 mx1.linux.local. ns1 IN A 192.168.128.221 ns2 IN A 192.168.128.222 mx1 IN A 192.168.128.221 linux.local. IN A 192.168.128.221 www IN CNAME linux.local. mail IN CNAME mx1 linux.rev $TTL 1D @ IN SOA ns1.linux.local. root.linux.local. ( 130915 ; serial 1D ; refresh 1H ; retry 1W ; expire 3H ) ; minimum IN NS ns1.linux.local. IN NS ns2.linux.local. ns1 IN A 192.168.128.221 ns2 IN A 192.168.128.222 3 IN PTR ns1.linux.local. 4 IN PTR ns2.linux.local. Udostępnij ten post Link to postu Udostępnij na innych stronach
Gość Kamikadze Zgłoś post Napisano Kwiecień 6, 2017 linux.local. IN NS ns1.linux.local. linux.local. IN NS ns2.linux.local. Udostępnij ten post Link to postu Udostępnij na innych stronach
mmmm21 98 Zgłoś post Napisano Kwiecień 7, 2017 Podmień linijkę listen-on port 53 { 127.0.0.1; 192.168.128.0; }; na listen-on { any; }; Wykonaj restart binda. Wygląda jakby dns nie nasłuchiwał na odpowiednim ip. 1 Udostępnij ten post Link to postu Udostępnij na innych stronach
DebekPL 0 Zgłoś post Napisano Kwiecień 7, 2017 (edytowany) Dnia 4/7/2017 o 08:58, mmmm21 napisał: Podmień linijkę listen-on port 53 { 127.0.0.1; 192.168.128.0; }; na listen-on { any; }; Wykonaj restart binda. Wygląda jakby dns nie nasłuchiwał na odpowiednim ip. To było rozwiązanie problemu. Zauważyłem chyba jeszcze jeden problem: 3 IN PTR ns1.linux.local. 4 IN PTR ns2.linux.local. 1) Czy tutaj zamiast 3 nie powinno być 221 a zamiast 4 222? 2) IN MX 10 mx1.linux.local. Czy jeśli dam wartość 11 to wtedy priorytet będzie wyższy? 3) A jeśli w Windowsie ustawię mój dns i chciałbym ustawić żeby po wpisaniu xxx.pl przekierowało mnie na mój ip to jaki wpis mogę dodać? Wystarczy, że dodam jeden wpis xxx.pl. IN A 192.168.128.221 ?? 4) Co robi search w pliku resolv.conf? 5) Jaka jest różnica pomiędzy serwisami named a named-chroot? Z góry dziękuję za pomoc Edytowano Kwiecień 7, 2017 przez DebekPL (zobacz historię edycji) Udostępnij ten post Link to postu Udostępnij na innych stronach
DebekPL 0 Zgłoś post Napisano Kwiecień 10, 2017 Znajdzie się ktoś pomocny? Udostępnij ten post Link to postu Udostępnij na innych stronach
nnd_newbie 10 Zgłoś post Napisano Kwiecień 10, 2017 Dnia 4/7/2017 o 09:45, DebekPL napisał: To było rozwiązanie problemu. Zauważyłem chyba jeszcze jeden problem: 3 IN PTR ns1.linux.local. 4 IN PTR ns2.linux.local. 1) Czy tutaj zamiast 3 nie powinno być 221 a zamiast 4 222? 2) IN MX 10 mx1.linux.local. Czy jeśli dam wartość 11 to wtedy priorytet będzie wyższy? 3) A jeśli w Windowsie ustawię mój dns i chciałbym ustawić żeby po wpisaniu xxx.pl przekierowało mnie na mój ip to jaki wpis mogę dodać? Wystarczy, że dodam jeden wpis xxx.pl. IN A 192.168.128.221 ?? 4) Co robi search w pliku resolv.conf? 5) Jaka jest różnica pomiędzy serwisami named a named-chroot? Z góry dziękuję za pomoc 1) To jest reverse DNS, powinny wskazywać na IP serwerów, więc sądzę, ze tak 2) Odwrotnie. Niższa liczba to większy priorytet. 3) Tego nie jestem pewny. Ogólnie ten wpis przekieruje xxx.pl na adres 192.168.128.221 (o ile dalej nie masz innych wpisów które go nadpiszą np. cname dla www.xxx.pl). 4) Pozwala Ci skrócić używane nazwy hostów. np. dla search "test.pl" jak użyjesz krótkiej nazwy "host" to będzie próbował wyszukać "host.test.pl". Dla większej liczby domen, zwróci pierwszy trafiony wynik. 5) http://www.tldp.org/HOWTO/Chroot-BIND-HOWTO-1.html Udostępnij ten post Link to postu Udostępnij na innych stronach
