j1gg 2 Zgłoś post Napisano Sierpień 17, 2016 Witam, panowie z mints wymienili mi dysk, postawili system i niby wszystko dziala. Mam jednak problem z polączeniem steam przy uruchamianiu serwera. Dostaje taki kominikat Could not establish connection to Steam servers. Moja komenda startowa -game csgo -console -usercon +map de_dust2 +ip MYIPHERE -port 27115 -maxplayers_override 32 -pidfile ogp_game_startup.pid +sv_setsteamaccount "MYTOKENHERE" +game_type "0" +game_mode "0" +clientport 28901 +tv_port 28721 Regułki iptables. root@mk249:~# iptables -S -P INPUT ACCEPT -P FORWARD ACCEPT -P OUTPUT ACCEPT Rcon status Could not establish connection to Steam servers. status hostname: Counter-Strike: Global Offensive version : 1.35.4.5/13545 356/6480 insecure (secure mode enabled, disconnected from Steam3) [iNVALID_STEAMID] udp/ip : 185.25.151.42:27015 os : Linux type : community dedicated map : de_dust2 players : 0 humans, 0 bots (20/0 max) (hibernating) Logi połączenia. 2016-08-17 01:178] [0,0] SetSteamID( [G:1:0] ) [2016-08-17 01:178] [1,2] Connect() starting connection (eNetQOSLevelMedium, 162.254.197.41:27020, UDP) [2016-08-17 01:17:43] [1,0] ConnectFailed('Connection Failed':0) (0.0.0.0:0, UDP) [2016-08-17 01:17:43] [0,0] StartAutoReconnect() will start in 0 seconds [2016-08-17 01:17:43] [1,6] Connect() starting connection (eNetQOSLevelMedium, 162.254.197.41:27020, UDP) [2016-08-17 01:17:48] [1,0] ConnectFailed('Connection Failed':0) (0.0.0.0:0, UDP) [2016-08-17 01:17:48] [0,0] StartAutoReconnect() will start in 5 seconds [2016-08-17 01:17:53] [1,8] Connect() starting connection (eNetQOSLevelMedium, 162.254.197.41:27020, UDP) [2016-08-17 01:17:58] [1,0] ConnectFailed('Connection Failed':0) (0.0.0.0:0, UDP) [2016-08-17 01:17:58] [0,0] StartAutoReconnect() will start in 4 seconds [2016-08-17 01:18:02] [1,10] Connect() starting connection (eNetQOSLevelMedium, 162.254.197.41:27020, UDP) [2016-08-17 01:18:07] [1,0] ConnectFailed('Connection Failed':0) (0.0.0.0:0, UDP) [2016-08-17 01:18:07] [0,0] StartAutoReconnect() will start in 7 seconds [2016-08-17 01:18:14] [1,12] Connect() starting connection (eNetQOSLevelMedium, 162.254.197.41:27020, UDP) [2016-08-17 01:18:19] [1,0] ConnectFailed('Connection Failed':0) (0.0.0.0:0, UDP) [2016-08-17 01:18:19] [0,0] StartAutoReconnect() will start in 8 seconds [2016-08-17 01:18:27] [1,14] Connect() starting connection (eNetQOSLevelMedium, 162.254.197.41:27020, UDP) [2016-08-17 01:182] [1,0] ConnectFailed('Connection Failed':0) (0.0.0.0:0, UDP) [2016-08-17 01:182] [0,0] StartAutoReconnect() will start in 12 seconds [2016-08-17 01:18:44] [1,16] Connect() starting connection (eNetQOSLevelMedium, 162.254.197.41:27020, UDP) [2016-08-17 01:18:49] [1,0] ConnectFailed('Connection Failed':0) (0.0.0.0:0, UDP) [2016-08-17 01:18:49] [0,0] StartAutoReconnect() will start in 28 seconds [2016-08-17 01:19:17] [1,18] Connect() starting connection (eNetQOSLevelMedium, 162.254.197.41:27020, UDP) [2016-08-17 01:19:22] [1,0] ConnectFailed('Connection Failed':0) (0.0.0.0:0, UDP) [2016-08-17 01:19:22] [0,0] StartAutoReconnect() will start in 28 seconds Pan z mints powiedział że po ich stronie wszystko jest okej. Wszedł na mój serwer zpingowal parę stron i niby działa. Myślę ze mints blokuje jakies porty i serwer csgo nie może połączyć sie ze steam. Dodam że na tym samym serwerze przed wymianą dysku wszystko śmigało ponad rok. Teraz pytanie, czy jest moze jakaś aplikacja/skrypt która sprawdzi czy ileś portów ma wyjście na świat? Udostępnij ten post Link to postu Udostępnij na innych stronach
MatX_ 3 Zgłoś post Napisano Sierpień 17, 2016 Szczerze mówiąc wątpię, żeby cokolwiek blokowali, ja nie spotkałem się z czymś takim u siebie na dedyku z MH, chyba, że po ataku DDoS. Udostępnij ten post Link to postu Udostępnij na innych stronach
likufanele 77 Zgłoś post Napisano Sierpień 17, 2016 (edytowany) Nie gram w CSGO ani tym bardziej nie stawiam serwerów, ale czy problem przypadkiem nie leży tutaj: [iNVALID_STEAMID] Nie wiem czy ci w czymś pomoże ale możesz sprawdzić te dwa linki: http://steamcommunity.com/groups/linuxgsm/discussions/0/458604254449402711/#c458604254452415995 https://forums.alliedmods.net/showthread.php?t=275901 Edytowano Sierpień 17, 2016 przez likufanele (zobacz historię edycji) Udostępnij ten post Link to postu Udostępnij na innych stronach
j1gg 2 Zgłoś post Napisano Sierpień 17, 2016 Już naprawione. Chyba jednak coś u nich było. Pan Michal napisał ze nic nie blokują a Pan Tomasz to naprawił. Udostępnij ten post Link to postu Udostępnij na innych stronach
