Desavil 88 Zgłoś post Napisano Styczeń 14, 2016 Witam. Mam "czystą" instalację DirectAdmina z użyciem konfiguracji CustomBuild 2.0 - Nginx (Proxy) + Apache oraz wersje php 5.5 i 5.6 przy użyciu dla nich php-fpm. Co równe 24h od momentu uruchomieniu Nginxa, wysypuje się on. W pliku z logami znajduje się wtedy następujący komunikat: 2016/01/14 19:02:02 [alert] 64949#0: fork() failed while spawning "worker process" (12: Cannot allocate memory) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: fork() failed while spawning "worker process" (12: Cannot allocate memory) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: fork() failed while spawning "worker process" (12: Cannot allocate memory) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: fork() failed while spawning "worker process" (12: Cannot allocate memory) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) 2016/01/14 19:02:02 [alert] 64949#0: sendmsg() failed (9: Bad file descriptor) Serwer posiada 4 rdzenie/wątki oraz 4 GB pamięci RAM - średnie wykorzystanie to 1,5 GB. W panelu DirectAdmin jest pokazane Użycie pamięci w Monitorze usług - wtedy kiedy Nginx się zawiesi, zawsze pokazuje 1,45 GB. Co ciekawsze, za dnia czasem pokazuje nawet 7 GB użycia pamięci (ciekawe skąd to się bierze), htop pokazuje prawidłowo ok. 1,5-2 GB. Udostępnij ten post Link to postu Udostępnij na innych stronach
Rolej 58 Zgłoś post Napisano Styczeń 14, 2016 worker proces - jaką masz tu wartość? Udostępnij ten post Link to postu Udostępnij na innych stronach
Desavil 88 Zgłoś post Napisano Styczeń 14, 2016 worker proces - jaką masz tu wartość? 4, bo: processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 60 model name : Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz stepping : 3 microcode : 0x1 cpu MHz : 3392.144 cache size : 8192 KB physical id : 0 siblings : 4 core id : 0 cpu cores : 4 apicid : 0 initial apicid : 0 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl eagerfpu pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm arat xsaveopt fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid bogomips : 6784.28 clflush size : 64 cache_alignment : 64 address sizes : 40 bits physical, 48 bits virtual power management: processor : 1 vendor_id : GenuineIntel cpu family : 6 model : 60 model name : Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz stepping : 3 microcode : 0x1 cpu MHz : 3392.144 cache size : 8192 KB physical id : 0 siblings : 4 core id : 1 cpu cores : 4 apicid : 1 initial apicid : 1 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl eagerfpu pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm arat xsaveopt fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid bogomips : 6784.28 clflush size : 64 cache_alignment : 64 address sizes : 40 bits physical, 48 bits virtual power management: processor : 2 vendor_id : GenuineIntel cpu family : 6 model : 60 model name : Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz stepping : 3 microcode : 0x1 cpu MHz : 3392.144 cache size : 8192 KB physical id : 0 siblings : 4 core id : 2 cpu cores : 4 apicid : 2 initial apicid : 2 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl eagerfpu pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm arat xsaveopt fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid bogomips : 6784.28 clflush size : 64 cache_alignment : 64 address sizes : 40 bits physical, 48 bits virtual power management: processor : 3 vendor_id : GenuineIntel cpu family : 6 model : 60 model name : Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz stepping : 3 microcode : 0x1 cpu MHz : 3392.144 cache size : 8192 KB physical id : 0 siblings : 4 core id : 3 cpu cores : 4 apicid : 3 initial apicid : 3 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl eagerfpu pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm arat xsaveopt fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid bogomips : 6784.28 clflush size : 64 cache_alignment : 64 address sizes : 40 bits physical, 48 bits virtual power management: Ustawiłem jeszcze dzisiaj (czyli: 4 [worker_processes] * 8192 [worker_connections] = 32768): worker_rlimit_nofile 32768; Udostępnij ten post Link to postu Udostępnij na innych stronach
Misiek08 285 Zgłoś post Napisano Styczeń 14, 2016 Zastanawiam się co ten DA kombinuje, że workery się restartują. Udostępnij ten post Link to postu Udostępnij na innych stronach
Rolej 58 Zgłoś post Napisano Styczeń 14, 2016 A spróbuj (tak testowo) zmienić 4 na auto. Ewentualnie zmniejsz odpowiednio connections i rlimit, gdyby to nie pomogło. Udostępnij ten post Link to postu Udostępnij na innych stronach
Desavil 88 Zgłoś post Napisano Styczeń 14, 2016 Zastanawiam się co ten DA kombinuje, że workery się restartują. Jak wywali te błędy po 24 godzinach działania nginxa, to do momentu aż go ręcznie nie zrestartuję, tak "wisi" zawieszony (choć proces jest uruchomiony). A spróbuj (tak testowo) zmienić 4 na auto. Ewentualnie zmniejsz odpowiednio connections i rlimit, gdyby to nie pomogło. Sprawdzę i dam znać za 24h. Udostępnij ten post Link to postu Udostępnij na innych stronach
Bartosz Z 236 Zgłoś post Napisano Styczeń 14, 2016 Sprawdzę i dam znać za 24h. Nie czekaj tyle, tylko przestaw sobie datę Udostępnij ten post Link to postu Udostępnij na innych stronach
Desavil 88 Zgłoś post Napisano Styczeń 14, 2016 Nie czekaj tyle, tylko przestaw sobie datę Chciałbym żeby to tak działało. Udostępnij ten post Link to postu Udostępnij na innych stronach
Pan Kot 1535 Zgłoś post Napisano Styczeń 14, 2016 Chciałbym żeby to tak działało. Zerknij w cron.daily, wyodrębnij sobie linijkę odpowiedzialną za daily crona DA i ją wyexecutuj, jak głupi to się nawet nie zorientuje. Udostępnij ten post Link to postu Udostępnij na innych stronach
Misiek08 285 Zgłoś post Napisano Styczeń 14, 2016 Tylko po co DA wymusza restart workerów... Udostępnij ten post Link to postu Udostępnij na innych stronach
Desavil 88 Zgłoś post Napisano Styczeń 14, 2016 Zerknij w cron.daily, wyodrębnij sobie linijkę odpowiedzialną za daily crona DA i ją wyexecutuj, jak głupi to się nawet nie zorientuje. W cron.daily nie ma żadnych zadań z DA. Jedynie w cron.d jest directadmin_cron, a w nim: * * * * * root /usr/local/directadmin/dataskq 2 0-23/6 * * * root echo 'action=vacation&value=all' >> /usr/local/directadmin/data/task.queue; #5 5 * * 0 root /sbin/quotaoff -a; /sbin/quotacheck -augm; /sbin/quotaon -a; 0 * * * * root echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue 20 4 1 * * root echo 'action=reset&value=all' >> /usr/local/directadmin/data/task.queue 0 4 * * * root echo 'action=check&value=license' >> /usr/local/directadmin/data/task.queue "Co równe 24 godziny" - miałem na myśli, że od momentu ręcznego uruchomienia/zrestartowania nginxa liczy się to 24 godziny, a nie że np. codziennie o godz. 19:00. Udostępnij ten post Link to postu Udostępnij na innych stronach
Pan Kot 1535 Zgłoś post Napisano Styczeń 14, 2016 W cron.daily nie ma żadnych zadań z DA. Jedynie w cron.d jest directadmin_cron, a w nim: * * * * * root /usr/local/directadmin/dataskq 2 0-23/6 * * * root echo 'action=vacation&value=all' >> /usr/local/directadmin/data/task.queue; #5 5 * * 0 root /sbin/quotaoff -a; /sbin/quotacheck -augm; /sbin/quotaon -a; 0 * * * * root echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue 20 4 1 * * root echo 'action=reset&value=all' >> /usr/local/directadmin/data/task.queue 0 4 * * * root echo 'action=check&value=license' >> /usr/local/directadmin/data/task.queue "Co równe 24 godziny" - miałem na myśli, że od momentu ręcznego uruchomienia/zrestartowania nginxa liczy się to 24 godziny, a nie że np. codziennie o godz. 19:00. Nie mam pojęcia dlaczego w takim razie. Udostępnij ten post Link to postu Udostępnij na innych stronach
Desavil 88 Zgłoś post Napisano Styczeń 15, 2016 (edytowany) I znów to samo (tak od 5 dni już)... W przeglądarce: ERR_CONNECTION_TIMED_OUT W ps aux tylko proces (brakuje workerów): root 57687 0.0 37.4 1571284 1519708 ? Ss sty14 0:05 nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf I w logach standardowo: 2016/01/15 19:01:01 [alert] 57687#0: fork() failed while spawning "worker process" (12: Cannot allocate memory) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: fork() failed while spawning "worker process" (12: Cannot allocate memory) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: fork() failed while spawning "worker process" (12: Cannot allocate memory) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: fork() failed while spawning "worker process" (12: Cannot allocate memory) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) 2016/01/15 19:01:01 [alert] 57687#0: sendmsg() failed (9: Bad file descriptor) Co mogę jeszcze zrobić, jakieś dodatkowe debugowanie włączyć, czy coś, aby ustalić przyczynę? Dodam, że DirectAdmin jest uruchomiony na wirtualizacji KVM (CPU w trybie Host). Edytowano Styczeń 15, 2016 przez Desavil (zobacz historię edycji) Udostępnij ten post Link to postu Udostępnij na innych stronach
Rolej 58 Zgłoś post Napisano Styczeń 15, 2016 /etc/nginx/nginx.conf [..] error_log /path/to/log debug; [..]Debug nginxa. Udostępnij ten post Link to postu Udostępnij na innych stronach
Misiek08 285 Zgłoś post Napisano Styczeń 20, 2016 Ustaw limit plików 2 razy wyższy i do tego sprawdź, czy użytkownik, na którym działa nginx nie ma jakichś małych limitów otwartych plików. To jest jedyna przyczyna jeżeli nginx jest w miarę nowy. Jedyny wpis, który znalazłem z tym samym problemem to ten: http://serverfault.com/questions/619337/nginx-out-of-memory-not-loading-new-vhosts Nginx ma problem przy bezsensownych przeładowaniach, gdy konfiguracja się nie zmieniła. Osobiście kiedyś dla testów miałem zrobiony reload co 1 minutę i nic się nie działo, ale zawsze trzymam najnowszą wersję na serwerze. Jak wyglądają wykresy użycia pamięci i SWAP? Udostępnij ten post Link to postu Udostępnij na innych stronach
KerbenII 19 Zgłoś post Napisano Styczeń 20, 2016 Możliwe, że nie masz ustawionego żadnego swapa i po prostu brakuje Ci pamięci RAM. Ja tak miałem z MariaDB - restartowała mi co parę godzin.Wystarczyło wyłączenie buforowania (performance_schema).Dla nginxa będzie to dodanie w pliku konfiguracyjnym( /etc/nginx/nginx.conf ) lub vhostachsendfile off; Jeżeli masz oryginalnego DA możesz też utworzyć ticket tutaj.Ich support jest nieźle ogarnięty i szybko zdiagnozuje Twój problem, a co najważniejsze napisze Ci krok po kroku co zrobił, aby go rozwiązać. Udostępnij ten post Link to postu Udostępnij na innych stronach
Desavil 88 Zgłoś post Napisano Styczeń 25, 2016 Próbowałem zwiększać limity, nic to nie dało. Pamięci RAM na pewno nie brakowało, co do swap, to jest on wyłączony. Problem rozwiązało.. zamiana Nginxa+Apache na samo Apache. Postawię przed nim prawdopodobnie Varhish'a i powinno być ok. Udostępnij ten post Link to postu Udostępnij na innych stronach
Pan Kot 1535 Zgłoś post Napisano Styczeń 25, 2016 Problem z nginxem rozwiązało usunięcie nginxa. ... OK. 1 Udostępnij ten post Link to postu Udostępnij na innych stronach
PapaSmerf 497 Zgłoś post Napisano Styczeń 26, 2016 @OP Zobacz na ten link: http://serverfault.com/questions/208916/understanding-max-file-descriptors-for-linux-and-nginx-and-best-value-for-worke. Udostępnij ten post Link to postu Udostępnij na innych stronach
Desavil 88 Zgłoś post Napisano Styczeń 26, 2016 Problem z nginxem rozwiązało usunięcie nginxa. ... OK. Niestety czasem tak trzeba, tym bardziej jeżeli jest to serwer produkcyjny. Na dalsze ewentualne testy przyjdzie czas. Udostępnij ten post Link to postu Udostępnij na innych stronach
