vavin
Problem z NGINX
Postawiłem sobie wordpressa na nginx. Jednak silnik limituje wysyłanie obrazków więc dodałem
http {
#Basic Settings
client_max_body_size 100m;
do nginx.conf tak to wygląda teraz :
user www-data;
worker_processes 4;
pid /var/run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
#Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript;
# nginx-naxsi config
# Uncomment it if you installed nginx-naxsi
#include /etc/nginx/naxsi_core.rules;
# nginx-passenger config
# Uncomment it if you installed nginx-passenger
#passenger_root /usr;
#passenger_ruby /usr/bin/ruby;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-available/*;
#mail {
# # See sample authentication script at:
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
Nie wiem w czym problem ale wyświetla błąd: Restarting nginx: nginx: [emerg] unknown directive "sendfile" in /etc/nginx/nginx.conf:11
nginx: configuration file /etc/nginx/nginx.conf test failed
Proszę o pomoc.
Podejrzewam, że za wcześnie, albo nie w tym miejscu, zamknąłeś nawias http {} (10. wiersz).
Mógłbyś mi dokładnie pokazać gdzie ? Podać gotowy kod ? Byłbym bardzo wdzięczny.
Edytowano przez vavin (zobacz historię edycji)
Spróbuj tak:
user www-data;
worker_processes 4;
events {
# multi_accept on;
http {
        #Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
#mail {
# # http://wiki.nginx.or...ApachePhpScript
# server {
# protocol   pop3;
# proxy      on;
# server {
# protocol   imap;
# proxy      on;
