rebrov 0 Zgłoś post Napisano Październik 24, 2014 Proszę o pomoc z domeną którą próbuję dodać do swojego serwera VPS w OVH Classic whois domena.pl DOMAIN NAME: domena.pl registrant type: organization nameservers: sdns2.ovh.net. vps111111.ovh.net. -------->>> zmieniłem na 111111 czy te DNS są proawidłowe ? cat /etc/bind/named.conf // This is the primary configuration file for the BIND DNS server named. // // Please read /usr/share/doc/bind9/README.Debian.gz for information on the // structure of BIND configuration files in Debian, *BEFORE* you customize // this configuration file. // // If you are just adding zones, please do that in /etc/bind/named.conf.local include "/etc/bind/named.conf.options"; include "/etc/bind/named.conf.local"; include "/etc/bind/named.conf.default-zones"; cat /etc/bind/named.conf.options options { directory "/var/cache/bind"; // If there is a firewall between you and nameservers you want // to talk to, you may need to fix the firewall to allow multiple // ports to talk. See http://www.kb.cert.org/vuls/id/800113 // If your ISP provided one or more IP addresses for stable // nameservers, you probably want to use them as forwarders. // Uncomment the following block, and insert the addresses replacing // the all-0's placeholder. // forwarders { // 0.0.0.0; // }; //======================================================================== // If BIND logs error messages about the root key being expired, // you will need to update your keys. See https://www.isc.org/bind-keys //======================================================================== dnssec-validation auto; // Protecting server against common attacks allow-recursion { localhost; localnets;}; allow-query-cache { localhost; localnets;}; auth-nxdomain no; # conform to RFC1035 listen-on-v6 { any; }; }; cat /etc/bind/named.conf.local // // Do any local configuration here // // Consider adding the 1918 zones here, if they are not used in your // organization //include "/etc/bind/zones.rfc1918"; cat /etc/bind/named.conf.default-zones // prime the server with knowledge of the root servers zone "." { type hint; file "/etc/bind/db.root"; }; // be authoritative for the localhost forward and reverse zones, and for // broadcast zones as per RFC 1912 zone "localhost" { type master; file "/etc/bind/db.local"; }; zone "127.in-addr.arpa" { type master; file "/etc/bind/db.127"; }; zone "0.in-addr.arpa" { type master; file "/etc/bind/db.0"; }; zone "255.in-addr.arpa" { type master; file "/etc/bind/db.255"; }; Udostępnij ten post Link to postu Udostępnij na innych stronach
spindritf 240 Zgłoś post Napisano Październik 24, 2014 No chyba OK. Teraz musisz stworzyć plik strefy i zrobić wpis dla swojej domeny w named.conf.local. Udostępnij ten post Link to postu Udostępnij na innych stronach
rebrov 0 Zgłoś post Napisano Październik 24, 2014 (edytowany) ok dodałem strefę do cat /etc/bind/named.conf.default-zones // prime the server with knowledge of the root servers zone "." { type hint; file "/etc/bind/db.root"; }; // be authoritative for the localhost forward and reverse zones, and for // broadcast zones as per RFC 1912 zone "localhost" { type master; file "/etc/bind/db.local"; }; zone "127.in-addr.arpa" { type master; file "/etc/bind/db.127"; }; zone "0.in-addr.arpa" { type master; file "/etc/bind/db.0"; }; zone "255.in-addr.arpa" { type master; file "/etc/bind/db.255"; }; zone "moja_domena.pl" { type master; file "moja_domena.pl"; allow-transfer { none; }; }; oraz utworzyłem moja_domena.pl cat /etc/bind/moja_domena.pl $ORIGIN moja_domena.pl. $TTL 12h @ IN SOA ns1 dnsmaster 2014102401 09h 5m 10d 1h IN NS ns1 IN NS ns2 IN A 11.111.11.111 -> IP mojego serwera * IN A 11.111.11.111 z konfiguracją jest wszystko ok named-checkzone moja_domena.pl /etc/bind/moja_domena.pl zone moja_domena.pl/IN: loaded serial 2014102401 OK lecz problem z domeną jest nadal dig @127.0.0.1 moja_domena.pl ; <<>> DiG 9.8.4-rpz2+rl005.12-P1 <<>> @127.0.0.1 moja_domena.pl ; (1 server found) ;; global options: +cmd ;; Got answer: ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 24005 ;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0 ;; QUESTION SECTION: ;moja-domena.pl. IN A ;; Query time: 0 msec ;; SERVER: 127.0.0.1#53(127.0.0.1) ;; WHEN: Fri Oct 24 10:19:18 2014 ;; MSG SIZE rcvd: 33 Edytowano Październik 24, 2014 przez rebrov (zobacz historię edycji) Udostępnij ten post Link to postu Udostępnij na innych stronach
spindritf 240 Zgłoś post Napisano Październik 24, 2014 Jeśli tak, to nie hostuj w ogóle samodzielnie tego serwera DNS. Ustaw DNS-y OVH i dodaj tylko w panelu rekord A wskazujący Twój serwer. Udostępnij ten post Link to postu Udostępnij na innych stronach
rebrov 0 Zgłoś post Napisano Październik 24, 2014 czy ta konfiguracja powyżej jest prawidłowa ? Udostępnij ten post Link to postu Udostępnij na innych stronach
spindritf 240 Zgłoś post Napisano Październik 24, 2014 Zobacz, że nic nie zwraca. Udostępnij ten post Link to postu Udostępnij na innych stronach
rebrov 0 Zgłoś post Napisano Październik 24, 2014 (edytowany) korekta /etc/bind/named.conf.options options { directory "/etc/bind"; allow-query-cache { none; }; allow-query { any; }; recursion no; version "najnowsza"; }; może komuś się przyda poszło ) Edytowano Październik 24, 2014 przez rebrov (zobacz historię edycji) Udostępnij ten post Link to postu Udostępnij na innych stronach
rebrov 0 Zgłoś post Napisano Październik 24, 2014 ehhh myślałem że ok jest a dalej coś nie tak dig @127.0.0.1 moja_domena.pl ; <<>> DiG 9.8.4-rpz2+rl005.12-P1 <<>> @127.0.0.1 moja_domena.pl ; (1 server found) ;; global options: +cmd ;; Got answer: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 14637 ;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2 ;; WARNING: recursion requested but not available ;; QUESTION SECTION: ;moja_domena.pl. IN A ;; ANSWER SECTION: moja_domena.pl. 43200 IN A 11.111.11.111 ;; AUTHORITY SECTION: moja_domena.pl. 43200 IN NS ns1.moja_domena.pl. moja_domena.pl. 43200 IN NS ns2.moja_domena.pl. ;; ADDITIONAL SECTION: ns1.moja_domena.pl. 43200 IN A 11.111.11.111 ns2.moja_domena.pl. 43200 IN A 11.111.11.111 ;; Query time: 0 msec ;; SERVER: 127.0.0.1#53(127.0.0.1) ;; WHEN: Fri Oct 24 13:11:10 2014 ;; MSG SIZE rcvd: 117 ping moja_domena.pl - działa dobrze wskazuje na mój serwer PING moja_domena.pl (11.111.11.111) 56(84) bytes of data. 64 bytes from moja_domena.pl (11.111.11.111): icmp_req=1 ttl=64 time=0.047 ms 64 bytes from moja_domena.pl (11.111.11.111): icmp_req=2 ttl=64 time=0.042 ms ^C problem jednak jest host moja_domena.pl Host moja_domena.pl not found: 3(NXDOMAIN) Udostępnij ten post Link to postu Udostępnij na innych stronach
