ml0dy
problem z uruchomieniem mysql
Witam.
Mam problem z uruchomieniem mysql.
root@vps:/var/db/mysql # /usr/local/etc/rc.d/mysql-server start
Starting mysql.
root@vps:/var/db/mysql # mysql -u root -p
Enter password:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
root@vps:/var/db/mysql # /usr/local/etc/rc.d/mysql-server status
mysql is not running.
root@vps:/usr/home/admin01 # cat /usr/local/etc/my.cnf
# The following options will be passed to all MySQL clients
[client]
#password = your_password
port = 3306
socket = /tmp/mysql.sock
# Here follows entries for some specific programs
# The MySQL server
[mysqld]
port = 3306
skip-external-locking
key_buffer_size = 16M
max_allowed_packet = 10M
table_open_cache = 64
sort_buffer_size = 512K
net_buffer_length = 8K
read_buffer_size = 256K
read_rnd_buffer_size = 512K
myisam_sort_buffer_size = 8M
#innodb_force_recovery = 1
expire_logs_days = 7
# Replication Master Server (default)
# binary logging is required for replication
log-bin=mysql-bin
# binary logging format - mixed recommended
binlog_format=mixed
# required unique id between 1 and 2^32 - 1
# defaults to 1 if master-host is not set
# but will not function as a master if omitted
server-id = 1
# Uncomment the following if you are using InnoDB tables
innodb_data_home_dir = /var/db/mysql
innodb_data_file_path = ibdata1:10M:autoextend
innodb_log_group_home_dir = /var/db/mysql
# You can set .._buffer_pool_size up to 50 - 80 %
# of RAM but beware of setting memory usage too high
innodb_buffer_pool_size = 16M
innodb_additional_mem_pool_size = 2M
# Set .._log_file_size to 25 % of buffer pool size
innodb_log_file_size = 5M
innodb_log_buffer_size = 8M
innodb_flush_log_at_trx_commit = 1
innodb_lock_wait_timeout = 50
[mysqldump]
quick
max_allowed_packet = 16M
[mysql]
no-auto-rehash
# Remove the next comment character if you are not familiar with SQL
#safe-updates
[myisamchk]
key_buffer_size = 20M
sort_buffer_size = 20M
read_buffer = 2M
write_buffer = 2M
[mysqlhotcopy]
interactive-timeout
Zrzut logów:
root@vps:/var/db/mysql # cat /var/db/mysql/vps.mojanazwa.com.pl.err
InnoDB: End of page dump
140422 13:20:30 InnoDB: Page checksum 3901004751, prior-to-4.0.14-form checksum 4133747994
InnoDB: stored checksum 3901004751, prior-to-4.0.14-form stored checksum 394340168
InnoDB: Page lsn 0 2593319967, low 4 bytes of lsn at page end 2593183091
InnoDB: Page number (if stored to page already) 249,
InnoDB: space id (if created with >= MySQL-4.1.1 and stored already) 0
InnoDB: Page may be a system page
InnoDB: Database page corruption on disk or a failed
InnoDB: file read of page 249.
InnoDB: You may have to recover from a backup.
InnoDB: It is also possible that your operating
InnoDB: system has corrupted its own file cache
InnoDB: and rebooting your computer removes the
InnoDB: error.
InnoDB: If the corrupt page is an index page
InnoDB: you can also try to fix the corruption
InnoDB: by dumping, dropping, and reimporting
InnoDB: the corrupt table. You can use CHECK
InnoDB: TABLE to scan your table for corruption.
InnoDB: about forcing recovery.
InnoDB: Ending processing because of a corrupt database page.
140422 13:20:30 InnoDB: Assertion failure in thread 683688704 in file buf0buf.c line 3602
InnoDB: We intentionally generate a memory trap.
InnoDB: Submit a detailed bug report to http://bugs.mysql.com.
InnoDB: If you get repeated assertion failures or crashes, even
InnoDB: immediately after the mysqld startup, there may be
InnoDB: corruption in the InnoDB tablespace. Please refer to
11:20:30 UTC - mysqld got signal 6 ;
This could be because you hit a bug. It is also possible that this binary
or one of the libraries it was linked against is corrupt, improperly built,
or misconfigured. This error can also be caused by malfunctioning hardware.
We will try our best to scrape up some info that will hopefully help
diagnose the problem, but since we have already crashed,
something is definitely wrong and this may fail.
key_buffer_size=16777216
read_buffer_size=262144
max_used_connections=0
max_threads=151
thread_count=0
connection_count=0
It is possible that mysqld could use up to
key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 133417 K bytes of memory
Hope that's ok; if not, decrease some variables in the equation.
140422 13:20:30 mysqld_safe mysqld from pid file /var/db/mysql/vps.mojanazwa.com.pl.pid ended
Liczę na waszą pomoc, dodam tylko że nie mam żadnego dumpa bazy :(
A jak dodam do my.cnf wpis:
innodb_force_recovery = 6
To mysql działa i strony ładnie się ładują ale nie bardzo wiem co z tym dalej zrobić bo jak dodam # przed innodb_force_recovery = 6 i zrobie restart mysql to przestaje działać.
Dzięki.
Edytowano przez ml0dy (zobacz historię edycji)
Uruchom z innodb_force_recovery=1 zrób kompletny dump bazy, upewnij się, że zrobił się poprawnie, wyczyść zupełnie katalog z danymi mysql, przygotuj nowe bazy systemowe przy użyciu mysql_install_db, załaduj dumpa.
Jeśli nie wstaje z innodb_force_recovery=1 - zwiększaj numerek o 1 aż wstanie. Jeśli nic Ci nie pomoże, zgłoś się do mnie na priv, zrobię Ci to za nieduże pieniądze.
