ShirakoDesign
Debian 6- Problem z instalacją Mono
Witam wszystkich bardzo serdecznie. Mam mały problem z instalacją Mono na Debian 6.
Updatowałem Debiana
apt-get update
Upgratowałem Debiana
apt-get upgrade
Później chciałem zainstalować Mono
sudo apt-get install mono-complete
Wszystko szło dobrze, do czasu... Po jakimś czasie zaczęły pojawiać się błędy:
generating monodoc search index... (this can take a while)
Problem: O:Mono.Math.BigInteger.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector2d.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector2l.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector2ul.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector4f.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector4i.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector4ui.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector8s.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector8us.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector16b.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector16sb.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:NpgsqlTypes.NpgsqlInet.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Microsoft.Build.BuildEngine.BuildProperty.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Microsoft.Build.Utilities.TaskItem.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:System.DateTimeOffset.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:System.Decimal.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:System.IntPtr.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:System.Nullable<T>.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:System.UIntPtr.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Bardzo proszę o pomoc.
Z góry dziękuję za każdą pomoc i pozdrawiam Damian.
PS. Nie wiem czy to ważne ale dodam że jest to VPS hostingowany przez http://speedhost.pl
Edytowano przez ShirakoDesign (zobacz historię edycji)
