manieqq 0 Zgłoś post Napisano Grudzień 28, 2013 (edytowany) Witam Zainstalowałem plugin RvSiteBuilder do DA w/g poradnika http://support.rvsitebuilder.com/index.php?x=&mod_id=2&id=249#.Ur8Vq9LuJKR instalacja przebiegła bez problemów nawet 3 razy odinstalowałem i instalowałem ponownie. Plugin się zainstalował i dodał do DA ale jak chce z niego skorzystać to otrzymuje błedy: Strict Standards: Non-static method RvsLibs_DirectAdmin::isDirectAdmin() should not be called statically in /usr/local/directadmin/plugins/rvsitebuilder/images/setup.php on line 101 Strict Standards: Non-static method RvsLibs_DirectAdmin::isDirectAdmin() should not be called statically in /usr/local/directadmin/plugins/rvsitebuilder/images/setup.php on line 108Strict Standards: Non-static method RvsLibs_DirectAdmin::isDirectAdmin() should not be called statically in /usr/local/directadmin/plugins/rvsitebuilder/images/setup.php on line 117HTTP/1.1 200 OKContent-Type: text/html; charset=utf-8rvsitebuilder :: License have a problem WARNING: Please, contact your host provider to install RVSitebuilder. How to install RVSiteBuilder? Kod w liniach wygląda tak: ///////////////////// check directadmin ///////////////////// require_once $rootDir . '/lib/RVSGL/rvsLibs/DirectAdmin.php'; if (RvsLibs_DirectAdmin::isDirectAdmin() == true && defined('RVS_SKIP_FIREPHP_LOG') === false) { define('RVS_SKIP_FIREPHP_LOG' , true); } function checkUserIsNotRoot() { if (RvsLibs_DirectAdmin::isDirectAdmin() == true) { return ($_SERVER['USERNAME'] != 'admin') ? true : false; } else { return (isset($_ENV['REMOTE_USER']) && $_ENV['REMOTE_USER'] != 'root') ? true : false; } } if (checkUserIsNotRoot() == true) { if (RvsLibs_DirectAdmin::isDirectAdmin() == true) { echo "HTTP/1.1 200 OK\n"; echo "Content-Type: text/html; charset=utf-8\n\n"; } echo('<html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">'); echo('<head>'); echo('<title>rvsitebuilder :: License have a problem</title>'); echo('<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />'); echo('<meta http-equiv="Content-Language" content="en" />'); echo('<div align="center"><table>'); echo('<tr>'); echo('<td>'); echo('<table>'); echo('<tr>'); echo('<td class="bordererror" width="60%" valign="middle" align="center">'); echo("<b>WARNING:</b> Please, contact your host provider to install RVSitebuilder. <br />"); echo('<a href="http://support.rvsitebuilder.com/index.php?x=&mod_id=2&id=249" target="_blank">How to install RVSiteBuilder?</a>'); echo('</td>'); echo('</tr>'); echo('</table>'); echo('</td>'); echo('</tr>'); echo('</table></div>'); echo('</body>'); echo('</html>'); exit; } Na czerwono zaznaczyłem gdzie jest problem. Proszę powiedzcie mi gdzie mogę mieć problem albo co nie mam załączone jakiek brakuje biblioteki, że otrzymuje takie błedy, uzywam PHP5.4 i dodałem regułe do kodu w pliku: php.ini error_reporting = E_ALL & ~E_DEPRECATED & ~E_STRICT display_errors = Off Przeszukałem Google i nie znalazłem informacji o w/w problemie nawet na zagranicznych forach. Pozdrawiam Mariusz Edytowano Grudzień 28, 2013 przez manieqq (zobacz historię edycji) Udostępnij ten post Link to postu Udostępnij na innych stronach
