m-itu
problem z widokiem dla lanu i zewnętrznym
Niby prosta sparawa serwer za routerem i jeden widok dla lanu drugi na zęwnątrz. Co jest źle że chce wysyłać widok internal?
Z serwera z zewnątrz
nslookup 7xy.pl
;; Got SERVFAIL reply from 62.129.250.10, trying next server
Server:         62.129.252.215
Address:        62.129.252.215#53
Non-authoritative answer:
Address: 192.168.0.101
named.conf
acl "siec" {
        192.168.0.0/24;
        127.0.0.1;
acl "trusted" {
        127.0.0.0/8;
        ::1/128;
options {
        directory "/var/bind";
        pid-file "/var/run/named/named.pid";
        listen-on-v6 { none; };
        listen-on { 127.0.0.1; 192.168.0.101; };
        allow-query {
                    trusted;
        allow-query-cache {
                      trusted;
        allow-transfer {
                     none;
        allow-update {
                /* Don't allow updates, e.g. via nsupdate. */
                none;
        version "czego?";
        auth-nxdomain no;
        /*auth-nxdomain yes;*/
        query-source address * port 53;
        transfer-source * port 53;
        notify-source * port 53;
        forward first;
        //forwarders {
        //      195.114.173.153;        // Netia
        //      195.116.55.69;  // Netia
        //      4.2.2.1;                // Level3 Public DNS
        //      4.2.2.2;                // Level3 Public DNS
        //      8.8.8.8;                // Google Open DNS
        //      8.8.4.4;                // Google Open DNS
       //dnssec-enable yes;
        //dnssec-validation yes;
        //dnssec-validation auto;
       //query-source address * port 53;
logging {
        channel default_log {
                file "/var/log/named/named.log" versions 5 size 10M;
                print-time yes;
                print-severity yes;
                print-category yes;
        category default { default_log; };
        category general { default_log; };
include "/etc/bind/rndc.key";
controls {
        inet 127.0.0.1 port 953 allow { 127.0.0.1/32; ::1/128; } keys { "rndc-key"; };
view "internal" {
    match-clients { siec; };
    allow-query { siec;  };
    recursion yes;
    allow-notify { none; };
    allow-recursion { siec;  };
    notify no;
        zone "." IN {
                type hint;
                file "/var/bind/root.cache";
        zone "localhost" IN {
                type master;
                file "pri/localhost.zone"; };
        zone "0.0.127.in-addr.arpa" IN {
                type master;
                file "pri/localhost.rev"; };
        zone "0.168.192.in-addr.arpa" IN  {
                type master;
                file "pri/lan.rev"; };
        zone "7xy.pl" IN {
                type master;
                file "pri/7xy.internal"; };
view "external" {
    match-clients { !localnets; any; };
    allow-transfer { 195.114.173.153; };
    notify yes;
    recursion no;
            zone "7xy.pl" IN {
                type master;
                file "pri/7xy.zone"; };
            zone "206.253.77.in-addr.arpa" IN {
                type master;
                file "pri/7xy.rev"; };
Najistotniejsze by zadziałało jeśli się jest za natem by wydzielić adres bramy z siecie wewnętrnej.
Firewall dla 53 na udp też...
acl "siec" {  192.168.0.101;
                192.168.0.102;
                192.168.0.103;
                192.168.0.105;
                127.0.0.1/8;
acl "trusted" { 127.0.0.0/8 ; ::1/128 ; };
acl "slave" { 192.168.0.1; 195.114.173.153; };
Tak będzie czytelniej:
acl "siec" {  192.168.0.1/24;
                !192.168.0.1;
                127.0.0.1/8;
options {
        listen-on {
                    127.0.0.1;
                    192.168.0.101;
        allow-query-cache       { siec; };
        allow-update            { none; };
        version                 "czego?";
        auth-nxdomain           no;
        recursion no;
        //forward first;
        //forwarders {
logging {
                print-time yes;
                print-severity yes;
                print-category yes;
        channel audit_log {
            // Send the security related messages to a separate file.
                file "/var/log/named/audit.log";
            severity debug;
        print-time yes; };
        category default { default_syslog; };
        category general { default_syslog; };
        category security { audit_log; default_syslog; };
        category config { default_syslog; };
        category resolver { audit_log; };
        category xfer-in { audit_log; };
        category xfer-out { audit_log; };
        category notify { audit_log; };
        category client { audit_log; };
        category network { audit_log; };
        category update { audit_log; };
        category queries { audit_log; };
        category lame-servers { audit_log; };
controls {
view "internal" {
    allow-transfer { none; };
    recursion yes;
    notify no;
        zone "." IN {
                type hint;
                file "/var/bind/root.cache"; };
                type master;
                type master;
                type master;
        zone "7xy.pl" IN {
                type master;
view "external" {
    match-clients { !siec; any; };
    allow-query { !siec; any; };
    allow-transfer { slave; };
    notify yes;
    recursion no;
        zone "." IN {
                type hint;
            zone "7xy.pl" IN {
                type master;
                type master;
