VenoxSkC
Problem z instalacja Joomla
Witam mam problem z instalacją joomla na net-speak.pl
SQL=CREATE TABLE IF NOT EXISTS `p86nq_usergroups` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT COMMENT 'Primary Key', `parent_id` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'Adjacency List Reference Id', `lft` int(11) NOT NULL DEFAULT '0' COMMENT 'Nested set lft.', `rgt` int(11) NOT NULL DEFAULT '0' COMMENT 'Nested set rgt.', `title` varchar(100) NOT NULL DEFAULT '', PRIMARY KEY (`id`), UNIQUE KEY `idx_usergroup_parent_title_lookup` (`parent_id`,`title`), KEY `idx_usergroup_title_lookup` (`title`), KEY `idx_usergroup_adjacency_lookup` (`parent_id`), KEY `idx_usergroup_nested_set_lookup` (`lft`,`rgt`) USING BTREE ) ENGINE=InnoDB DEFAULT CHARSET=utf8 AUTO_INCREMENT=9
SQL=INSERT INTO `p86nq_usergroups` (`id`, `parent_id`, `lft`, `rgt`, `title`) VALUES (1, 0, 1, 18, 'Public'), (2, 1, 8, 15, 'Registered'), (3, 2, 9, 14, 'Author'), (4, 3, 10, 13, 'Editor'), (5, 4, 11, 12, 'Publisher'), (6, 1, 4, 7, 'Manager'), (7, 6, 5, 6, 'Administrator'), (8, 1, 16, 17, 'Super Users'), (9, 1, 2, 3, 'Guest')
Table '243_adres.am8rw_viewlevels' doesn't exist SQL=TRUNCATE `am8rw_viewlevels`
Table '243_adres.am8rw_viewlevels' doesn't exist SQL=INSERT IGNORE INTO `am8rw_viewlevels` (`id`, `title`, `ordering`, `rules`) VALUES (1, 'Public', 0, '[1]'), (2, 'Registered', 1, '[6,2,8]'), (3, 'Special', 2, '[6,3,8]'), (4, 'Customer Access Level (Example)', 3, '[6,3,12]'), (5, 'Guest', 0, '[13]')
Jest postęp juz dalej lecz kolejny błąd
Edytowano przez VenoxSkC (zobacz historię edycji)
