Desavil
[Problem] Bind - connection timed out; no servers could be reached
Witam.
Na serwerach master, slave DNS wykonując komendy typu ping na domenę, subdomeny są wykonywane bez problemów.
Jeżeli wykonuję to z innego serwera, domu nazwy nie są rozpoznawane, z komunikatem: ping: unknown host domena.pl
Polecenie dig z innego serwera zwraca błąd: connection timed out; no servers could be reached
Najdziwniejsze jest to, że na stronie http://www.whatsmydns.net/ wszystkie zmiany jakie dokonuję są tam rozpoznawane po kilkudziesięciu minutach.
W logach niema żadnych błędów:
Jun 17 22:22:47 nsXXX named[7453]: starting BIND 9.7.3 -u bind -t /var/lib/named
Jun 17 22:22:47 nsXXX named[7453]: built with '--prefix=/usr' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--sysconfdir=/etc/bind' '--localstatedir=/var' '--enable-threads' '--enable-largefile' '--with-libtool' '--enable-shared' '--enable-static' '--with-openssl=/usr' '--with-gssapi=/usr' '--with-gnu-ld' '--with-dlz-postgres=no' '--with-dlz-mysql=no' '--with-dlz-bdb=yes' '--with-dlz-filesystem=yes' '--with-dlz-ldap=yes' '--with-dlz-stub=yes' '--with-geoip=/usr' '--enable-ipv6' 'CFLAGS=-fno-strict-aliasing -DDIG_SIGCHASE -O2' 'LDFLAGS=' 'CPPFLAGS='
Jun 17 22:22:47 nsXXX named[7453]: adjusted limit on open files from 1024 to 1048576
Jun 17 22:22:47 nsXXX named[7453]: found 8 CPUs, using 8 worker threads
Jun 17 22:22:47 nsXXX named[7453]: using up to 4096 sockets
Jun 17 22:22:47 nsXXX named[7453]: loading configuration from '/etc/bind/named.conf'
Jun 17 22:22:47 nsXXX named[7453]: reading built-in trusted keys from file '/etc/bind/bind.keys'
Jun 17 22:22:47 nsXXX named[7453]: using default UDP/IPv4 port range: [1024, 65535]
Jun 17 22:22:47 nsXXX named[7453]: using default UDP/IPv6 port range: [1024, 65535]
Jun 17 22:22:47 nsXXX named[7453]: listening on IPv4 interface lo, 127.0.0.1#53
Jun 17 22:22:47 nsXXX named[7453]: listening on IPv4 interface eth0, XXX.XXX.XXX.XXX#53
Jun 17 22:22:47 nsXXX named[7453]: listening on IPv6 interface lo, ::1#53
Jun 17 22:22:47 nsXXX named[7453]: generating session key for dynamic DNS
Jun 17 22:22:47 nsXXX named[7453]: set up managed keys zone for view _default, file 'managed-keys.bind'
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: 254.169.IN-ADDR.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: 2.0.192.IN-ADDR.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: 100.51.198.IN-ADDR.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: 113.0.203.IN-ADDR.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: 255.255.255.255.IN-ADDR.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.IP6.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.IP6.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: D.F.IP6.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: 8.E.F.IP6.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: 9.E.F.IP6.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: A.E.F.IP6.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: B.E.F.IP6.ARPA
Jun 17 22:22:47 nsXXX named[7453]: automatic empty zone: 8.B.D.0.1.0.0.2.IP6.ARPA
Jun 17 22:22:47 nsXXX named[7453]: command channel listening on 127.0.0.1#953
Jun 17 22:22:47 nsXXX named[7453]: command channel listening on ::1#953
Jun 17 22:22:47 nsXXX named[7453]: zone 0.in-addr.arpa/IN: loaded serial 1
Jun 17 22:22:47 nsXXX named[7453]: zone 127.in-addr.arpa/IN: loaded serial 1
Jun 17 22:22:47 nsXXX named[7453]: zone 255.in-addr.arpa/IN: loaded serial 1
Jun 17 22:22:47 nsXXX named[7453]: zone localhost/IN: loaded serial 2
Jun 17 22:22:47 nsXXX named[7453]: zone domena.pl/IN: loaded serial 1371500401
Jun 17 22:22:47 nsXXX named[7453]: managed-keys-zone ./IN: loaded serial 0
Jun 17 22:22:47 nsXXX named[7453]: running
Jun 17 22:22:47 nsXXX named[7453]: zone domena.pl/IN: sending notifies (serial 1371500401)
Jun 17 22:22:47 nsXXX named[7453]: client xxx.xxx.xxx.xxx#60805: transfer of 'domena.pl/IN': AXFR-style IXFR started
Jun 17 22:22:47 nsXXX named[7453]: client xxx.xxx.xxx.xxx#60805: transfer of 'domena.pl/IN': AXFR-style IXFR ended
nslookup (z serwera innego niż serwery DNS)
Server:         127.0.0.1
Address:        127.0.0.1#53
** server can't find ns1.domena.pl: NXDOMAIN
Polecenie dig z serwera master DNS:
; <<>> DiG 9.7.3 <<>> +trace domena.pl
;; global options: +cmd
.                       3600000 IN      NS      M.ROOT-SERVERS.NET.
.                       3600000 IN      NS      B.ROOT-SERVERS.NET.
.                       3600000 IN      NS      L.ROOT-SERVERS.NET.
.                       3600000 IN      NS      E.ROOT-SERVERS.NET.
.                       3600000 IN      NS      I.ROOT-SERVERS.NET.
.                       3600000 IN      NS      H.ROOT-SERVERS.NET.
.                       3600000 IN      NS      K.ROOT-SERVERS.NET.
.                       3600000 IN      NS      C.ROOT-SERVERS.NET.
.                       3600000 IN      NS      A.ROOT-SERVERS.NET.
.                       3600000 IN      NS      F.ROOT-SERVERS.NET.
.                       3600000 IN      NS      J.ROOT-SERVERS.NET.
.                       3600000 IN      NS      G.ROOT-SERVERS.NET.
.                       3600000 IN      NS      D.ROOT-SERVERS.NET.
;; Received 228 bytes from 127.0.0.1#53(127.0.0.1) in 0 ms
pl.                     172800  IN      NS      g-dns.pl.
pl.                     172800  IN      NS      e-dns.pl.
pl.                     172800  IN      NS      a-dns.pl.
pl.                     172800  IN      NS      f-dns.pl.
pl.                     172800  IN      NS      h-dns.pl.
pl.                     172800  IN      NS      c-dns.pl.
pl.                     172800  IN      NS      d-dns.pl.
pl.                     172800  IN      NS      i-dns.pl.
;; Received 397 bytes from 192.228.79.201#53(B.ROOT-SERVERS.NET) in 148 ms
domena.pl.                86400   IN      NS      ns2.domena.pl.
domena.pl.                86400   IN      NS      ns1.domena.pl.
;; Received 93 bytes from 195.187.245.44#53(a-dns.pl) in 31 ms
domena.pl.                180     IN      A       ZZZ.ZZZ.ZZZ.ZZZ
domena.pl.                180     IN      NS      ns1.domena.pl.
domena.pl.                180     IN      NS      ns2.domena.pl.
;; Received 109 bytes from YYY.YYY.YYY.YYY#53(ns2.domena.pl) in 0 ms
Wynik polecenia dig z innego serwera niż serwery DNS:
.                       416627  IN      NS      h.root-servers.net.
.                       416627  IN      NS      e.root-servers.net.
.                       416627  IN      NS      i.root-servers.net.
.                       416627  IN      NS      a.root-servers.net.
.                       416627  IN      NS      l.root-servers.net.
.                       416627  IN      NS      c.root-servers.net.
.                       416627  IN      NS      b.root-servers.net.
.                       416627  IN      NS      f.root-servers.net.
.                       416627  IN      NS      k.root-servers.net.
.                       416627  IN      NS      g.root-servers.net.
.                       416627  IN      NS      d.root-servers.net.
.                       416627  IN      NS      m.root-servers.net.
.                       416627  IN      NS      j.root-servers.net.
;; Received 436 bytes from 127.0.0.1#53(127.0.0.1) in 0 ms
;; Received 397 bytes from 2001:500:3::42#53(l.root-servers.net) in 58 ms
;; Received 93 bytes from 156.154.100.15#53(i-dns.pl) in 4 ms
;; connection timed out; no servers could be reached
Konfiguracja wygląda następująco:
named.conf.options
acl "trusted" { 127.0.0.1; ::1; };
options {
        version "DNS";
        directory "/var/cache/bind";
        forwarders { 213.186.33.99; 8.8.8.8; 8.8.4.4; };
        auth-nxdomain no;
        listen-on { XXX.XXX.XXX.XXX; 127.0.0.1; };
        listen-on-v6 { ::1; };
        allow-recursion { trusted; };
named.conf.local
zone "domena.pl" {
        type master;
        file "/etc/bind/zone/domena.pl";
        notify yes;
        allow-transfer { YYY.YYY.YYY.YYY; };
$TTL 180
$ORIGIN domena.pl.
@ IN SOA ns1.domena.pl. admin.domena.pl. (1371499502 86400 3600 3600000 300)
                                               IN A      213.186.33.5
www                                            IN CNAME  domena.pl.
ns1                                            IN A      XXX.XXX.XXX.XXX
ns2                                            IN A      YYY.YYY.YYY.YYY
subdomena                                 IN A      ZZZ.ZZZ.ZZZ.ZZZ
W iptables dodane wpisy:
iptables -A INPUT -d XXX.XXX.XXX -p tcp --dport 53 -j ACCEPT
iptables -A INPUT -d XXX.XXX.XXX -p udp --dport 53 -j ACCEPT
Edytowano przez regdos (zobacz historię edycji)
A jakie adresy DNS masz ustawione na tej maszynie na której Ci nie widzi domeny. Spróbuj zmienić na opendns (208.67.222.222) czy googledns (8.8.8.8) albo prościej użyj polecenia dig @8.8.8.8 towja_domena .
Edytowano przez igor_s (zobacz historię edycji)
Na maszynie innej w OVH mam DNSy domyślne, czyli (resolv.conf) na serwerach master i secondary zawartość tych plików również jest taka sama:
nameserver 127.0.0.1
nameserver 213.186.33.99
Z domu próbowałem i również ten problem występuje - DNSy googla 8.8.8.8, 8.8.4.4
Właśnie w pierwszej kolejności instalując bind9 zastosowałem się do instrukcji http://ovh.to/VxN3EMu
Poza tym wcześniej port 53 miałem zablokowany cały czas na firewallu, więc nie mogli zablokować. :)
A secondary DNS bez problemu pobiera strefę z master.
Gość patrys
Chcesz pomocy na forum publicznym, to podaj domenę, już tyle razy ten temat był wałkowany.
Podanie nazwy domeny nic nie da ponieważ jest ona aktualnie skierowana na DNSy operatora domeny i tam znajduje się strefa, co działa.
Spróbowałem skonfigurować DNS secondary na tego co daje OVH (sdns2.ovh.net), wpisałem w panelu serwera dedykowanego w tej zakładce nazwę domeny, skonfigurowałem w bind9 na master allow-transfer na secondary OVH i wyskakuje błąd w panelu OVH przy każdym odświeżeniu:
domena.pl	2013-06-18 15:53	xxx.xxx.xxx.xxx	sdns2.ovh.net	  BŁĄD Domena: domena.pl
Stan aktualny:
BŁĄD : zone domena.pl/IN: notify from xxx.xxx.xxx.xxx#48088: refresh in progress, refresh check queued
Od xxx.xxx.xxx.xxx dzień 2013-06-18 16:09:34
Ostatnie transfery:
BŁĄD : zone domena.pl/IN: notify from xxx.xxx.xxx.xxx#46974: refresh in progress, refresh check queued
Od xxx.xxx.xxx.xxx dzień 2013-06-18 16:04:35
BŁĄD : zone domena.pl/IN: notify from xxx.xxx.xxx.xxx#51860: refresh in progress, refresh check queued
Od xxx.xxx.xxx.xxx dzień 2013-06-18 15:59:35
BŁĄD : zone domena.pl/IN: notify from xxx.xxx.xxx.xxx#20389: refresh in progress, refresh check queued
Od xxx.xxx.xxx.xxx dzień 2013-06-18 15:55:41
BŁĄD : zone domena.pl/IN: notify from xxx.xxx.xxx.xxx#50679: refresh in progress, refresh check queued
Od xxx.xxx.xxx.xxx dzień 2013-06-18 15:54:35
BŁĄD : zone domena.pl/IN: notify from xxx.xxx.xxx.xxx#30409: refresh in progress, refresh check queued
Od xxx.xxx.xxx.xxx dzień 2013-06-18 15:52:17
BŁĄD : zone domena.pl/IN: notify from xxx.xxx.xxx.xxx#5007: refresh in progress, refresh check queued
Od xxx.xxx.xxx.xxx dzień 2013-06-18 15:49:35
BŁĄD : zone domena.pl/IN: notify from xxx.xxx.xxx.xxx#46768: refresh in progress, refresh check queued
Od xxx.xxx.xxx.xxx dzień 2013-06-18 15:44:34
BŁĄD : zone domena.pl/IN: notify from xxx.xxx.xxx.xxx#33696: refresh in progress, refresh check queued
Od xxx.xxx.xxx.xxx dzień 2013-06-18 15:39:34
BŁĄD : zone domena.pl/IN: notify from xxx.xxx.xxx.xxx#56156: refresh in progress, refresh check queued
Od xxx.xxx.xxx.xxx dzień 2013-06-18 15:34:35
Dziwne jest to, że dla testu podpiąłem jeszcze freedns.42.pl jako 3 zapasowy DNS i bez problemu pobrało strefę, ale nie widzę żeby ona się aktualizowała też nie wiem dlaczego tak się dzieje.
Logi tcpdumpa wyglądają następująco (w przypadku sdns2.ovh.net na mój serwer):
13:10:31.368228 IP nsXXX.ovh.net.12884 > sdns2.ovh.net.domain: 19604 notify [b2&3=0x2400] [1a] SOA? domena.pl. (94)
13:10:31.372693 IP sdns2.ovh.net.domain > nsXXX.ovh.net.12884: 19604 notify*- 0/0/0 (25)
13:15:31.162943 IP nsXXX.ovh.net.55266 > sdns2.ovh.net.domain: 20910 notify [b2&3=0x2400] [1a] SOA? domena.pl. (94)
13:15:31.167129 IP sdns2.ovh.net.domain > nsXXX.ovh.net.55266: 20910 notify*- 0/0/0 (25)
