FilipS
Problem z Proftpd
dzisiaj samo z siebie wysypało mi się na serwerze proftpd. Podczas wgrywania pliku wyświetla informacje że jest to niemożliwe, przeglądać pliki można normalnie.
W logach mam coś takiego:
ProFTPd [34328] 80.53.107.162 [24/maj/2013:14:20:18 +0200] "USER usern" 331
ProFTPd [34328] 80.53.107.162 [24/maj/2013:14:20:19 +0200] "PASS (hidden)" 230
ProFTPd [16216] 80.53.107.162 [24/maj/2013:14:40:12 +0200] "USER usern" 331
ProFTPd [16216] 80.53.107.162 [24/maj/2013:14:40:12 +0200] "PASS (hidden)" 230
Konfiguracja mojego Proftpd jest taka:
ServerName		"ProFTPd"
ServerType          	standalone
Port			21
PassivePorts		35000 35999
UseReverseDNS		off
TimesGMT		off
TimeoutLogin		120
TimeoutIdle		600
TimeoutNoTransfer	900
TimeoutStalled		3600
ScoreboardFile			/var/run/proftpd/proftpd.pid
TransferLog		/var/log/proftpd/xferlog.legacy
LogFormat		default "%h %l %u %t \"%r\" %s %b"
LogFormat		auth    "%v [%P] %h %t \"%r\" %s"
LogFormat		write   "%h %l %u %t \"%r\" %s %b"
#DON'T modify this log format.  Its used by DirectAdmin to determine user usage
LogFormat		userlog "%u %b %m %a"
ExtendedLog		/var/log/proftpd/IP.bytes WRITE,READ userlog
AuthUserFile                    /etc/proftpd.passwd
DefaultServer		on
AuthOrder mod_auth_file.c
#AuthPAM off
<IfModule mod_tls.c>
	TLSEngine on
	TLSLog /var/log/proftpd/proftpd.tls.log
	TLSProtocol SSLv23
	#TLSProtocol TLSv1
	TLSVerifyClient off
	TLSRequired off
	#Certificates
	TLSRSACertificateFile /etc/exim.cert
	TLSRSACertificateKeyFile /etc/exim.key
	#TLSCACertificateFile /etc/ftpd/root.cert.pem
	TLSCipherSuite HIGH:MEDIUM:+TLSv1:!SSLv2:+SSLv3
</IfModule>
<Global>
	DeferWelcome		on
	RequireValidShell	no
	DefaultRoot		~
	DirFakeUser on ftp
	DirFakeGroup on ftp
	User			ftp
	Group			ftp
	#UserAlias		anonymous ftp
	AllowStoreRestart	on
	AllowRetrieveRestart	on
	ListOptions		-a
	Umask			022
	DisplayLogin		welcome.msg
	DisplayChdir		readme
	AllowOverwrite		yes
	IdentLookups		off
	ExtendedLog		/var/log/proftpd/access.log WRITE,READ write
	ExtendedLog		/var/log/proftpd/auth.log AUTH auth
	# Paranoia logging level....
	#ExtendedLog    /var/log/proftpd/paranoid.log ALL default
		TLSEngine on
	</IfModule>
</Global>
Include /etc/proftpd.vhosts.conf
Przy restarcie Proftpd wywala mi coś takiego:
/etc/init.d/proftpd: line 43: [: =: oczekiwano operatora jednoargumentowego
Czy wie ktoś może w czym jest problem? Jeszcze 2 godziny temu wszystko działało, nie zmieniałem nic w konfiguracji, wysypało się samo z siebie.
Na serwerze zainstalowany jest directadmin.
Edytowano przez FilipS (zobacz historię edycji)
  Dnia 5/24/2013 o 13:13, Łukasz B. napisał:
Błąd tkwi w lini 43
Tyle ja też wiem. Może jakaś podpowiedź co trzeba zmienić?
Tylko dotyczy to pliku /etc/init.d/proftpd a nie pliku konfiguracyjnego.
Plik /etc/init.d/proftpd wygląda tak:
#!/bin/sh
# Startup script for ProFTPD
# chkconfig: - 85 15
# description: ProFTPD is an enhanced FTP server with a focus towards \
#              simplicity, security, and ease of configuration. \
#              It features a very Apache-like configuration syntax, \
#              and a highly customizable server infrastructure, \
#              including support for multiple 'virtual' FTP servers, \
#              anonymous FTP, and permission-based directory visibility.
# processname: proftpd
# config: /etc/proftpd.conf
# pidfile: /var/run/proftpd/proftpd.pid
### BEGIN INIT INFO
# Provides: proftpd ftpserver
# Required-Start: $local_fs $network $named $remote_fs
# Required-Stop: $local_fs $network $named $remote_fs
# Default-Stop: 0 1 6
# Short-Description: ProFTPd FTP Server
# Description: ProFTPd is an enhanced FTP server with a focus towards
### END INIT INFO
# Source function library.
. /etc/rc.d/init.d/functions
# Source networking configuration.
. /etc/sysconfig/network
# Source ProFTPD configuration.
PROFTPD_OPTIONS=""
if [ -f /etc/sysconfig/proftpd ]; then
      . /etc/sysconfig/proftpd
fi
# Check that networking is enabled.
[ ${NETWORKING} = "no" ] && exit 1
# Make sure the binary is present.
[ -x /usr/sbin/proftpd ] || exit 5
RETVAL=0
prog="proftpd"
start() {
        echo -n $"Starting $prog: "
        daemon proftpd $PROFTPD_OPTIONS 2>/dev/null
        RETVAL=$?
        echo
        [ $RETVAL -eq 0 ] && touch /var/lock/subsys/proftpd
stop() {
        echo -n $"Shutting down $prog: "
        killproc proftpd
        RETVAL=$?
        echo
        [ $RETVAL -eq 0 ] && rm -f /var/lock/subsys/proftpd
# See how we were called.
case "$1" in
        start)
                start
        stop)
                stop
        status)
                status proftpd
                RETVAL=$?
        restart)
                stop
                start
        try-restart|condrestart)
                if [ -f /var/lock/subsys/proftpd ]; then
                        stop
                        start
                fi
        reload|force-reload|reread)
                echo -n $"Re-reading $prog configuration: "
                killproc proftpd -HUP
                RETVAL=$?
                echo
        suspend)
                hash ftpshut >/dev/null 2>&1
                if [ $? = 0 ]; then
                        if [ $# -gt 1 ]; then
                                shift
                                echo -n "Suspending with '$*'"
                                ftpshut "$@"
                                RETVAL=$?
                        else
                                echo -n "Suspending NOW"
                                ftpshut now "Maintenance in progress"
                                RETVAL=$?
                        fi
                else
                        echo -n "No way to suspend"
                        RETVAL=1
                fi
                echo
        resume)
                if [ -f /etc/shutmsg ]; then
 echo -n "Allowing sessions again"
                        rm -f /etc/shutmsg
                else
                        echo -n "Was not suspended"
                        RETVAL=2
                fi
                echo
                echo -n "Usage: $prog {start|stop|restart|try-restart|reload|status|reread|resume"
                hash ftpshut
                if [ $? = 1 ]; then
                        echo '}'
                else
                        echo '|suspend}'
                        echo 'suspend accepts additional arguments, which are passed to ftpshut(8)'
                fi
                exit 2
esac
exit $RETVAL
To wygląda na oryginalny plik z paczki debiana. Nie nadpisałeś sobie proftpd za pomocą apt-get?
Plik startowy DA jest w /usr/local/directadmin/custombuild/ i nazywa się proftpd_debian, możesz spróbować zastąpić ten aktualny tym z DA.
Po podmianie pliku proftpd nie wypluwa już błędu przy restarcie ale plików nadal nie przyjmuje.
Wgram jeszcze ostatnie logi z paranoid.log:
XX.XXX.XX.XX UNKNOWN admin [24/maj/2013:17:15:30 +0200] "TYPE I" 200 -
XX.XXX.XX.XX UNKNOWN admin [24/maj/2013:17:15:30 +0200] "PORT 77,254,185,45,228,54" 200 -
XX.XXX.XX.XX UNKNOWN admin [24/maj/2013:17:15:30 +0200] "STOR ogloszenia.txt" 452 512
XX.XXX.XX.XX UNKNOWN admin [24/maj/2013:17:15:30 +0200] "SIZE ogloszenia.txt" 213 -
XX.XXX.XX.XX UNKNOWN admin [24/maj/2013:17:15:33 +0200] "TYPE A" 200 -
XX.XXX.XX.XX UNKNOWN admin [24/maj/2013:17:15:33 +0200] "PORT 77,254,185,45,228,55" 200 -
XX.XXX.XX.XX UNKNOWN admin [24/maj/2013:17:15:33 +0200] "MLSD" 226 5329
