Gość mpm1122
[Problem] Z wysyłaniem maili
Gość mpm1122
Witam, ostatnio próbowałem postawić serwer www, po długiej walce z MySQL przyszedł czas email niestety sendmail mi nie działa i nie wiem czemu :< Zamieszczam tutaj to co się stało podczas instalacji
login as: root
root@minecraft.mepi.pl's password:
Linux xen-01-46-4-182-71.vps.statnet.pl 2.6.32-5-xen-686 #1 SMP Sun May 6 07:43:																								 49 UTC 2012 i686
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
You have new mail.
Last login: Tue Aug  7 11:51:24 2012 from arv157.neoplus.adsl.tpnet.pl
xen-01-46-4-182-71:~# mc
xen-01-46-4-182-71:~# aptitude remove sendmail
The following partially installed packages will be configured:
 mysql-server mysql-server-5.1
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Setting up mysql-server-5.1 (5.1.63-0+squeeze1) ...
Stopping MySQL database server: mysqld.
Starting MySQL database server: mysqld.
Checking for corrupt, not cleanly closed and upgrade needing tables..
Setting up mysql-server (5.1.63-0+squeeze1) ...
xen-01-46-4-182-71:~# apt-get --purge remove sendmail
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package sendmail is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
xen-01-46-4-182-71:~# sudo /etc/init.d/apache2 restart
Restarting web server: apache2 ... waiting .
xen-01-46-4-182-71:~#  sudo apt-get install sendmail
The following extra packages will be installed:
 sendmail-bin
Suggested packages:
 sendmail-doc rmail sasl2-bin libsasl2-modules
The following packages will be REMOVED:
 postfix
The following NEW packages will be installed:
 sendmail sendmail-bin
0 upgraded, 2 newly installed, 1 to remove and 11 not upgraded.
Need to get 0 B/1139 kB of archives.
After this operation, 1024 kB disk space will be freed.
Do you want to continue [Y/n]? Y
dpkg: postfix: dependency problems, but removing anyway as you requested:
sensible-mda depends on sendmail-bin | mail-transport-agent; however:
 Package sendmail-bin is not installed.
 Package mail-transport-agent is not installed.
 Package sendmail-bin which provides mail-transport-agent is not installed.
 Package postfix which provides mail-transport-agent is to be removed.
(Reading database ... 24695 files and directories currently installed.)
Removing postfix ...
Stopping Postfix Mail Transport Agent: postfix.
Processing triggers for man-db ...
Selecting previously deselected package sendmail-bin.
(Reading database ... 24537 files and directories currently installed.)
Unpacking sendmail-bin (from .../sendmail-bin_8.14.3-9.4_i386.deb) ...
Setting up sendmail-bin (8.14.3-9.4) ...
update-rc.d: warning: sendmail stop runlevel arguments (0 1 6) do not match LSB																								  Default-Stop values (1)
update-alternatives: using /usr/lib/sm.bin/sendmail to provide /usr/sbin/sendmai																								 l-mta (sendmail-mta) in auto mode.
update-alternatives: using /usr/lib/sm.bin/sendmail to provide /usr/sbin/sendmai																								 l-msp (sendmail-msp) in auto mode.
update-alternatives: warning: not replacing /usr/share/man/man8/sendmail.8.gz wi																								 th a link.
Saving old /etc/mail/sendmail.cf as /etc/mail/sendmail.cf.old ...
Stopping Mail Transport Agent (MTA): sendmail.
Updating sendmail environment ...
Reading configuration from /etc/mail/sendmail.conf.
Validating configuration.
Writing configuration to /etc/mail/sendmail.conf.
Writing /etc/cron.d/sendmail.
Could not open /etc/mail/databases(No such file or directory), creating it.
Creating /etc/mail/databases...
Checking filesystem, this may take some time - it will not hang!
 ...   Done.
Checking for installed MDAs...
sasl2-bin not installed, not configuring sendmail support.
To enable sendmail SASL2 support at a later date, invoke "/usr/share/sendmail/up																								 date_auth"
Creating/Updating SSL(for TLS) information
Creating /etc/mail/tls/starttls.m4...
You already have sendmail certificates
*** *** *** WARNING *** WARNING *** WARNING *** WARNING *** *** ***
Everything you need to support STARTTLS (encrypted mail transmission
and user authentication via certificates) is installed and configured
but is *NOT* being used.
To enable sendmail to use STARTTLS, you need to:
1) Add this line to /etc/mail/sendmail.mc and optionally
  to /etc/mail/submit.mc:
 include(`/etc/mail/tls/starttls.m4')dnl
2) Run sendmailconfig
3) Restart sendmail
Checking {sendmail,submit}.mc and related databases...
Creating /etc/mail/Makefile...
Disabling HOST statistics file(/var/lib/sendmail/host_status).
Creating /etc/mail/sendmail.cf...
*** ERROR: FEATURE() should be before MAILER()
*** MAILER(`local') must appear after FEATURE(`always_add_domain')*** ERROR: FEA																								 TURE() should be before MAILER()
*** MAILER(`local') must appear after FEATURE(`allmasquerade')*** ERROR: FEATURE																								 () should be before MAILER()
Creating /etc/mail/submit.cf...
Informational: confCR_FILE file empty: /etc/mail/relay-domains
Informational: confCT_FILE file empty: /etc/mail/trusted-users
Updating /etc/mail/access...
Updating /etc/mail/aliases...
/etc/mail/aliases: 4 aliases, longest 10 bytes, 66 bytes total
Warning: These messages were issued while creating sendmail.cf
    make sure they are benign before starting sendmail!
Errors in generating sendmail.cf
Starting Mail Transport Agent (MTA): sendmail.
Selecting previously deselected package sendmail.
(Reading database ... 24586 files and directories currently installed.)
Unpacking sendmail (from .../sendmail_8.14.3-9.4_all.deb) ...
Setting up sendmail (8.14.3-9.4) ...
Odpuść sobie sendmaila zainstaluj inny MTA - np. Exim lub Postfix, zresztą z tego co wrzuciłeś widać jest, że postfix był już zainstalowany.
A sprawdziłeś chociaż w logach dlaczego nie wysyłał?
Gość mpm1122
Tak wyglądała instalacja postfix'a
xen-01-46-4-182-71:~#  sudo apt-get install postfix
Suggested packages:
 postfix-mysql postfix-pgsql postfix-ldap postfix-pcre sasl2-bin
 libsasl2-modules resolvconf postfix-cdb mail-reader ufw
 sendmail-bin
 postfix
0 upgraded, 1 newly installed, 1 to remove and 11 not upgraded.
Need to get 0 B/1328 kB of archives.
After this operation, 1282 kB of additional disk space will be used.
Preconfiguring packages ...
dpkg: sendmail-bin: dependency problems, but removing anyway as you requested:
 Package sendmail-bin is to be removed.
 Package sendmail-bin which provides mail-transport-agent is to be removed.
(Reading database ... 24569 files and directories currently installed.)
Removing sendmail-bin ...
Selecting previously deselected package postfix.
(Reading database ... 24521 files and directories currently installed.)
Unpacking postfix (from .../postfix_2.7.1-1+squeeze1_i386.deb) ...
Setting up postfix (2.7.1-1+squeeze1) ...
Adding group `postfix' (GID 108) ...
Done.
Adding system user `postfix' (UID 105) ...
Adding new user `postfix' (UID 105) with group `postfix' ...
Not creating home directory `/var/spool/postfix'.
Creating /etc/postfix/dynamicmaps.cf
Adding tcp map entry to /etc/postfix/dynamicmaps.cf
Adding group `postdrop' (GID 109) ...
Done.
setting myhostname: xen-01-46-4-182-71.vps.statnet.pl
setting alias maps
setting alias database
setting myorigin
setting destinations: xen-01-46-4-182-71.vps.statnet.pl, localhost.vps.statnet.p																								 l, , localhost
setting relayhost:
setting mynetworks: 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
setting mailbox_command
setting mailbox_size_limit: 0
setting recipient_delimiter: +
setting inet_interfaces: all
WARNING: /etc/aliases exists, but does not have a root alias.
Postfix is now set up with a default configuration.  If you need to make
changes, edit
/etc/postfix/main.cf (and others) as needed.  To view Postfix configuration
values, see postconf(1).
After modifying main.cf, be sure to run '/etc/init.d/postfix reload'.
Running newaliases
Starting Postfix Mail Transport Agent: postfix.
xen-01-46-4-182-71:~# /etc/init.d/postfix reload
Reloading Postfix configuration...postfix/postfix-script: fatal: the Postfix mail system is not running
failed.
xen-01-46-4-182-71:~# /etc/init.d/postfix start
failed.
Niestety nie wiem jaki plik odpowiada za logi postfixa
Spróbuj tak:
/etc/init.d/postfix stop
/etc/init.d/sendmail stop
Najlepiej to wywali sendmail, problem może być wtedy też gdyż masz zainstalowany sendmail i postfix te dwa serwery mogą używać jednego portu naraz.
Ani jeden ani drugi nie może uruchomić się gdy port jest zajęty. Tak samo jak byś chciał odpalić lighttpd gdy masz uruchomiony apache2 :)
edit:
I podejrzewam że użytkownik ma odpalonego sendmaila a próbuje odpalić jeszcze postfixa i mu się wykrzacza.
Ale cóż bez logów to i szklana kula nic nie pomoże :D
Gość mpm1122
kafi nie...
Tutaj daje log z chyba postfixa
Aug  7 11:34:30 xen-01-46-4-182-71 sendmail[30529]: alias database /etc/mail/aliases rebuilt by root
Aug  7 11:34:30 xen-01-46-4-182-71 sendmail[30529]: /etc/mail/aliases: 4 aliases, longest 10 bytes, 66 bytes total
Aug  7 11:34:30 xen-01-46-4-182-71 sm-mta[30583]: starting daemon (8.14.3): SMTP+queueing@00:10:00
Aug  7 11:35:07 xen-01-46-4-182-71 sensible-mda[30627]: sensible-mda - Required parameters elided.
Aug  7 11:36:59 xen-01-46-4-182-71 sendmail[30805]: q779ax9m030805: from=www-data, size=653, class=0, nrcpts=1, msgid=<7c5bec6b2b8b6b17bad68edcee99bae1@minecraft.mepi.pl>, relay=www-data@localhost
Aug  7 11:36:59 xen-01-46-4-182-71 sm-mta[30806]: q779axFu030806: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=760, class=0, nrcpts=1, msgid=<7c5bec6b2b8b6b17bad68edcee99bae1@minecraft.mepi.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 11:36:59 xen-01-46-4-182-71 sendmail[30805]: q779ax9m030805: to=michalmpm12@gmail.com, ctladdr=www-data (33/33), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30653, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q779axFu030806 Message accepted for delivery)
Aug  7 11:36:59 xen-01-46-4-182-71 sendmail[30810]: q779axbG030810: from=www-data, size=619, class=0, nrcpts=1, msgid=<7b214bd2f5a7dce6a3edb029ad2c7501@minecraft.mepi.pl>, relay=www-data@localhost
Aug  7 11:36:59 xen-01-46-4-182-71 sm-mta[30811]: q779ax9w030811: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=726, class=0, nrcpts=1, msgid=<7b214bd2f5a7dce6a3edb029ad2c7501@minecraft.mepi.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 11:36:59 xen-01-46-4-182-71 sendmail[30810]: q779axbG030810: to=mpm1122@wp.pl, ctladdr=www-data (33/33), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30619, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q779ax9w030811 Message accepted for delivery)
Aug  7 11:36:59 xen-01-46-4-182-71 sm-mta[30808]: STARTTLS=client, relay=gmail-smtp-in.l.google.com., version=TLSv1/SSLv3, verify=FAIL, cipher=RC4-SHA, bits=128/128
Aug  7 11:37:00 xen-01-46-4-182-71 sm-mta[30808]: q779axFu030806: to=<michalmpm12@gmail.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:00:01, xdelay=00:00:01, mailer=esmtp, pri=120760, relay=gmail-smtp-in.l.google.com. [173.194.70.26], dsn=2.0.0, stat=Sent (OK 1344332216 r63si25280915wed.42)
Aug  7 11:37:00 xen-01-46-4-182-71 sm-mta[30813]: STARTTLS=client, relay=mx.wp.pl., version=TLSv1/SSLv3, verify=FAIL, cipher=AES256-SHA, bits=256/256
Aug  7 11:37:00 xen-01-46-4-182-71 sm-mta[30813]: q779ax9w030811: to=<mpm1122@wp.pl>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:00:01, xdelay=00:00:01, mailer=esmtp, pri=120726, relay=mx.wp.pl. [212.77.101.4], dsn=5.0.0, stat=Service unavailable
Aug  7 11:37:00 xen-01-46-4-182-71 sm-mta[30813]: q779ax9w030811: q779b09w030813: DSN: Service unavailable
Aug  7 11:37:01 xen-01-46-4-182-71 sm-mta[30813]: q779b09w030813: to=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, delay=00:00:01, xdelay=00:00:01, mailer=local, pri=30000, dsn=2.0.0, stat=Sent
Aug  7 11:39:02 xen-01-46-4-182-71 sendmail[30855]: q779d1TN030855: from=root, size=436, class=0, nrcpts=1, msgid=<201208070939.q779d1TN030855@xen-01-46-4-182-71.vps.statnet.pl>, relay=root@localhost
Aug  7 11:39:02 xen-01-46-4-182-71 sm-mta[30856]: q779d2fc030856: from=<root@xen-01-46-4-182-71.vps.statnet.pl>, size=770, class=0, nrcpts=1, msgid=<201208070939.q779d1TN030855@xen-01-46-4-182-71.vps.statnet.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 11:39:02 xen-01-46-4-182-71 sendmail[30855]: q779d1TN030855: to=root, ctladdr=root (0/0), delay=00:00:01, xdelay=00:00:00, mailer=relay, pri=30436, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q779d2fc030856 Message accepted for delivery)
Aug  7 11:39:03 xen-01-46-4-182-71 sm-mta[30857]: q779d2fc030856: to=<root@xen-01-46-4-182-71.vps.statnet.pl>, ctladdr=<root@xen-01-46-4-182-71.vps.statnet.pl> (0/0), delay=00:00:01, xdelay=00:00:01, mailer=local, pri=31036, dsn=2.0.0, stat=Sent
Aug  7 11:39:31 xen-01-46-4-182-71 sendmail[30870]: q779dV6n030870: from=www-data, size=651, class=0, nrcpts=1, msgid=<8d564a038da7281658feea0ba4d29e73@minecraft.mepi.pl>, relay=www-data@localhost
Aug  7 11:39:31 xen-01-46-4-182-71 sm-mta[30871]: q779dVYX030871: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=758, class=0, nrcpts=1, msgid=<8d564a038da7281658feea0ba4d29e73@minecraft.mepi.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 11:39:31 xen-01-46-4-182-71 sendmail[30870]: q779dV6n030870: to=michalmpm12@gmail.com, ctladdr=www-data (33/33), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30651, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q779dVYX030871 Message accepted for delivery)
Aug  7 11:39:31 xen-01-46-4-182-71 sendmail[30875]: q779dV27030875: from=www-data, size=617, class=0, nrcpts=1, msgid=<667b03515d10f1fca7f35346c7e157a1@minecraft.mepi.pl>, relay=www-data@localhost
Aug  7 11:39:31 xen-01-46-4-182-71 sm-mta[30876]: q779dVnp030876: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=724, class=0, nrcpts=1, msgid=<667b03515d10f1fca7f35346c7e157a1@minecraft.mepi.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 11:39:31 xen-01-46-4-182-71 sendmail[30875]: q779dV27030875: to=mpm112@wp.pl, ctladdr=www-data (33/33), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30617, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q779dVnp030876 Message accepted for delivery)
Aug  7 11:39:31 xen-01-46-4-182-71 sm-mta[30873]: STARTTLS=client, relay=gmail-smtp-in.l.google.com., version=TLSv1/SSLv3, verify=FAIL, cipher=RC4-SHA, bits=128/128
Aug  7 11:39:32 xen-01-46-4-182-71 sm-mta[30873]: q779dVYX030871: to=<michalmpm12@gmail.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:00:01, xdelay=00:00:01, mailer=esmtp, pri=120758, relay=gmail-smtp-in.l.google.com. [173.194.70.27], dsn=2.0.0, stat=Sent (OK 1344332369 z49si25275214wem.70)
Aug  7 11:39:32 xen-01-46-4-182-71 sm-mta[30878]: STARTTLS=client, relay=mx.wp.pl., version=TLSv1/SSLv3, verify=FAIL, cipher=AES256-SHA, bits=256/256
Aug  7 11:39:32 xen-01-46-4-182-71 sm-mta[30878]: q779dVnp030876: to=<mpm112@wp.pl>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:00:01, xdelay=00:00:01, mailer=esmtp, pri=120724, relay=mx.wp.pl. [212.77.101.4], dsn=5.0.0, stat=Service unavailable
Aug  7 11:39:32 xen-01-46-4-182-71 sm-mta[30878]: q779dVnp030876: q779dWnp030878: DSN: Service unavailable
Aug  7 11:39:32 xen-01-46-4-182-71 sm-mta[30878]: q779dWnp030878: to=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=30000, dsn=2.0.0, stat=Sent
Aug  7 11:42:47 xen-01-46-4-182-71 postfix/master[31659]: fatal: bind 0.0.0.0 port 25: Address already in use
Aug  7 11:44:59 xen-01-46-4-182-71 postfix/postdrop[32148]: warning: unable to look up public/pickup: No such file or directory
Aug  7 11:44:59 xen-01-46-4-182-71 postfix/postdrop[32151]: warning: unable to look up public/pickup: No such file or directory
Aug  7 11:51:51 xen-01-46-4-182-71 postfix/master[32522]: fatal: bind 0.0.0.0 port 25: Address already in use
Aug  7 12:09:01 xen-01-46-4-182-71 postfix/postdrop[537]: warning: unable to look up public/pickup: No such file or directory
Aug  7 12:39:01 xen-01-46-4-182-71 postfix/postdrop[1230]: warning: unable to look up public/pickup: No such file or directory
Aug  7 13:09:01 xen-01-46-4-182-71 postfix/postdrop[1883]: warning: unable to look up public/pickup: No such file or directory
Aug  7 13:39:01 xen-01-46-4-182-71 postfix/postdrop[2557]: warning: unable to look up public/pickup: No such file or directory
Aug  7 14:09:01 xen-01-46-4-182-71 postfix/postdrop[3309]: warning: unable to look up public/pickup: No such file or directory
Aug  7 14:29:52 xen-01-46-4-182-71 sendmail[4855]: alias database /etc/mail/aliases rebuilt by root
Aug  7 14:29:52 xen-01-46-4-182-71 sendmail[4855]: /etc/mail/aliases: 4 aliases, longest 10 bytes, 66 bytes total
Aug  7 14:29:53 xen-01-46-4-182-71 sm-mta[4909]: starting daemon (8.14.3): SMTP+queueing@00:10:00
Aug  7 14:39:01 xen-01-46-4-182-71 sendmail[4948]: q77Cd1Kv004948: from=root, size=436, class=0, nrcpts=1, msgid=<201208071239.q77Cd1Kv004948@xen-01-46-4-182-71.vps.statnet.pl>, relay=root@localhost
Aug  7 14:39:01 xen-01-46-4-182-71 sm-mta[4949]: q77Cd1Wt004949: from=<root@xen-01-46-4-182-71.vps.statnet.pl>, size=770, class=0, nrcpts=1, msgid=<201208071239.q77Cd1Kv004948@xen-01-46-4-182-71.vps.statnet.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 14:39:01 xen-01-46-4-182-71 sendmail[4948]: q77Cd1Kv004948: to=root, ctladdr=root (0/0), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30436, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q77Cd1Wt004949 Message accepted for delivery)
Aug  7 14:39:01 xen-01-46-4-182-71 sm-mta[4950]: q77Cd1Wt004949: to=<root@xen-01-46-4-182-71.vps.statnet.pl>, ctladdr=<root@xen-01-46-4-182-71.vps.statnet.pl> (0/0), delay=00:00:00, xdelay=00:00:00, mailer=local, pri=31036, dsn=2.0.0, stat=Sent
Aug  7 15:07:13 xen-01-46-4-182-71 sendmail[5031]: q77D7DmH005031: from=www-data, size=658, class=0, nrcpts=1, msgid=<f9a18682edcf6aabaad7a83c02721dbf@minecraft.mepi.pl>, relay=www-data@localhost
Aug  7 15:07:14 xen-01-46-4-182-71 sm-mta[5032]: q77D7DFW005032: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=765, class=0, nrcpts=1, msgid=<f9a18682edcf6aabaad7a83c02721dbf@minecraft.mepi.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 15:07:14 xen-01-46-4-182-71 sendmail[5031]: q77D7DmH005031: to=michalmpm12@gmail.com, ctladdr=www-data (33/33), delay=00:00:01, xdelay=00:00:01, mailer=relay, pri=30658, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q77D7DFW005032 Message accepted for delivery)
Aug  7 15:07:14 xen-01-46-4-182-71 sm-mta[5034]: STARTTLS=client, relay=gmail-smtp-in.l.google.com., version=TLSv1/SSLv3, verify=FAIL, cipher=RC4-SHA, bits=128/128
Aug  7 15:07:15 xen-01-46-4-182-71 sendmail[5036]: q77D7ETa005036: from=www-data, size=624, class=0, nrcpts=1, msgid=<6cee2f8d2a517c850850e68ab129741b@minecraft.mepi.pl>, relay=www-data@localhost
Aug  7 15:07:15 xen-01-46-4-182-71 sm-mta[5034]: q77D7DFW005032: to=<michalmpm12@gmail.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:00:02, xdelay=00:00:01, mailer=esmtp, pri=120765, relay=gmail-smtp-in.l.google.com. [173.194.70.27], dsn=2.0.0, stat=Sent (OK 1344344831 w13si19656559bkv.82)
Aug  7 15:07:15 xen-01-46-4-182-71 sm-mta[5037]: q77D7FgH005037: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=731, class=0, nrcpts=1, msgid=<6cee2f8d2a517c850850e68ab129741b@minecraft.mepi.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 15:07:15 xen-01-46-4-182-71 sendmail[5036]: q77D7ETa005036: to=h1503005@rtrtr.com, ctladdr=www-data (33/33), delay=00:00:01, xdelay=00:00:00, mailer=relay, pri=30624, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q77D7FgH005037 Message accepted for delivery)
Aug  7 15:07:16 xen-01-46-4-182-71 sm-mta[5039]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 15:07:17 xen-01-46-4-182-71 sm-mta[5039]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:00:02, xdelay=00:00:02, mailer=esmtp, pri=120731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 15:09:01 xen-01-46-4-182-71 sendmail[5047]: q77D91eN005047: from=root, size=436, class=0, nrcpts=1, msgid=<201208071309.q77D91eN005047@xen-01-46-4-182-71.vps.statnet.pl>, relay=root@localhost
Aug  7 15:09:01 xen-01-46-4-182-71 sm-mta[5048]: q77D91bn005048: from=<root@xen-01-46-4-182-71.vps.statnet.pl>, size=770, class=0, nrcpts=1, msgid=<201208071309.q77D91eN005047@xen-01-46-4-182-71.vps.statnet.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 15:09:01 xen-01-46-4-182-71 sendmail[5047]: q77D91eN005047: to=root, ctladdr=root (0/0), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30436, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q77D91bn005048 Message accepted for delivery)
Aug  7 15:09:01 xen-01-46-4-182-71 sm-mta[5049]: q77D91bn005048: to=<root@xen-01-46-4-182-71.vps.statnet.pl>, ctladdr=<root@xen-01-46-4-182-71.vps.statnet.pl> (0/0), delay=00:00:00, xdelay=00:00:00, mailer=local, pri=31036, dsn=2.0.0, stat=Sent
Aug  7 15:09:54 xen-01-46-4-182-71 sm-mta[5052]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 15:09:55 xen-01-46-4-182-71 sm-mta[5052]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:02:40, xdelay=00:00:02, mailer=esmtp, pri=210731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 15:19:54 xen-01-46-4-182-71 sm-mta[5330]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 15:19:54 xen-01-46-4-182-71 sm-mta[5330]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:12:39, xdelay=00:00:01, mailer=esmtp, pri=300731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 15:29:53 xen-01-46-4-182-71 sm-mta[5780]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 15:29:54 xen-01-46-4-182-71 sm-mta[5780]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:22:39, xdelay=00:00:01, mailer=esmtp, pri=390731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 15:39:01 xen-01-46-4-182-71 sendmail[6568]: q77Dd1hO006568: from=root, size=436, class=0, nrcpts=1, msgid=<201208071339.q77Dd1hO006568@xen-01-46-4-182-71.vps.statnet.pl>, relay=root@localhost
Aug  7 15:39:01 xen-01-46-4-182-71 sm-mta[6569]: q77Dd1c1006569: from=<root@xen-01-46-4-182-71.vps.statnet.pl>, size=770, class=0, nrcpts=1, msgid=<201208071339.q77Dd1hO006568@xen-01-46-4-182-71.vps.statnet.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 15:39:01 xen-01-46-4-182-71 sendmail[6568]: q77Dd1hO006568: to=root, ctladdr=root (0/0), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30436, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q77Dd1c1006569 Message accepted for delivery)
Aug  7 15:39:02 xen-01-46-4-182-71 sm-mta[6570]: q77Dd1c1006569: to=<root@xen-01-46-4-182-71.vps.statnet.pl>, ctladdr=<root@xen-01-46-4-182-71.vps.statnet.pl> (0/0), delay=00:00:01, xdelay=00:00:00, mailer=local, pri=31036, dsn=2.0.0, stat=Sent
Aug  7 15:39:53 xen-01-46-4-182-71 sm-mta[6634]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 15:39:54 xen-01-46-4-182-71 sm-mta[6634]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:32:39, xdelay=00:00:01, mailer=esmtp, pri=480731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 15:49:53 xen-01-46-4-182-71 sm-mta[7167]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 15:49:54 xen-01-46-4-182-71 sm-mta[7167]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:42:39, xdelay=00:00:01, mailer=esmtp, pri=570731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 15:59:53 xen-01-46-4-182-71 sm-mta[8194]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 15:59:54 xen-01-46-4-182-71 sm-mta[8194]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:52:39, xdelay=00:00:01, mailer=esmtp, pri=660731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 16:09:01 xen-01-46-4-182-71 sendmail[9103]: q77E91pc009103: from=root, size=436, class=0, nrcpts=1, msgid=<201208071409.q77E91pc009103@xen-01-46-4-182-71.vps.statnet.pl>, relay=root@localhost
Aug  7 16:09:01 xen-01-46-4-182-71 sm-mta[9104]: q77E91D1009104: from=<root@xen-01-46-4-182-71.vps.statnet.pl>, size=770, class=0, nrcpts=1, msgid=<201208071409.q77E91pc009103@xen-01-46-4-182-71.vps.statnet.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 16:09:01 xen-01-46-4-182-71 sendmail[9103]: q77E91pc009103: to=root, ctladdr=root (0/0), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30436, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q77E91D1009104 Message accepted for delivery)
Aug  7 16:09:01 xen-01-46-4-182-71 sm-mta[9105]: q77E91D1009104: to=<root@xen-01-46-4-182-71.vps.statnet.pl>, ctladdr=<root@xen-01-46-4-182-71.vps.statnet.pl> (0/0), delay=00:00:00, xdelay=00:00:00, mailer=local, pri=31036, dsn=2.0.0, stat=Sent
Aug  7 16:09:54 xen-01-46-4-182-71 sm-mta[9187]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 16:09:55 xen-01-46-4-182-71 sm-mta[9187]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=01:02:40, xdelay=00:00:02, mailer=esmtp, pri=750731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 16:19:54 xen-01-46-4-182-71 sm-mta[10284]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 16:19:54 xen-01-46-4-182-71 sm-mta[10284]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=01:12:39, xdelay=00:00:01, mailer=esmtp, pri=840731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 16:29:54 xen-01-46-4-182-71 sm-mta[11460]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 16:29:54 xen-01-46-4-182-71 sm-mta[11460]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=01:22:39, xdelay=00:00:01, mailer=esmtp, pri=930731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 16:38:39 xen-01-46-4-182-71 postfix/master[13714]: fatal: bind 0.0.0.0 port 25: Address already in use
Aug  7 16:39:01 xen-01-46-4-182-71 postfix/postdrop[13811]: warning: unable to look up public/pickup: No such file or directory
Aug  7 16:39:24 xen-01-46-4-182-71 postfix/postfix-script[13899]: fatal: the Postfix mail system is not running
Aug  7 16:39:32 xen-01-46-4-182-71 postfix/master[14007]: fatal: bind 0.0.0.0 port 25: Address already in use
Aug  7 16:39:38 xen-01-46-4-182-71 postfix/postfix-script[14042]: fatal: the Postfix mail system is not running
Aug  7 16:39:53 xen-01-46-4-182-71 sm-mta[14100]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 16:39:54 xen-01-46-4-182-71 sm-mta[14100]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=01:32:39, xdelay=00:00:01, mailer=esmtp, pri=1020731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 16:39:57 xen-01-46-4-182-71 postfix/master[14189]: fatal: bind 0.0.0.0 port 25: Address already in use
Aug  7 16:45:48 xen-01-46-4-182-71 postfix/postdrop[15441]: warning: unable to look up public/pickup: No such file or directory
Aug  7 16:45:48 xen-01-46-4-182-71 postfix/postdrop[15445]: warning: unable to look up public/pickup: No such file or directory
Aug  7 16:49:54 xen-01-46-4-182-71 sm-mta[16305]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 16:49:54 xen-01-46-4-182-71 sm-mta[16305]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=01:42:39, xdelay=00:00:01, mailer=esmtp, pri=1110731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 16:59:53 xen-01-46-4-182-71 sm-mta[17513]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 16:59:54 xen-01-46-4-182-71 sm-mta[17513]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=01:52:39, xdelay=00:00:01, mailer=esmtp, pri=1200731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 17:09:01 xen-01-46-4-182-71 postfix/postdrop[18828]: warning: unable to look up public/pickup: No such file or directory
Aug  7 17:09:53 xen-01-46-4-182-71 sm-mta[18953]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 17:09:54 xen-01-46-4-182-71 sm-mta[18953]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=02:02:39, xdelay=00:00:01, mailer=esmtp, pri=1290731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 17:19:53 xen-01-46-4-182-71 sm-mta[20424]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 17:19:54 xen-01-46-4-182-71 sm-mta[20424]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=02:12:39, xdelay=00:00:01, mailer=esmtp, pri=1380731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/master[21125]: daemon started -- version 2.7.1, configuration /etc/postfix
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/pickup[21131]: 9C8131F4179: uid=33 from=<www-data>
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/cleanup[21133]: 9C8131F4179: message-id=<aca5e2637fd84a46b4fffdc8e42e4b8c@minecraft.mepi.pl>
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/qmgr[21132]: 9C8131F4179: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=737, nrcpt=1 (queue active)
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/pickup[21131]: AFDDC1F415B: uid=0 from=<root>
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/cleanup[21133]: AFDDC1F415B: message-id=<20120807152349.AFDDC1F415B@xen-01-46-4-182-71.vps.statnet.pl>
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/qmgr[21132]: AFDDC1F415B: from=<root@xen-01-46-4-182-71.vps.statnet.pl>, size=767, nrcpt=1 (queue active)
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/pickup[21131]: B08131F411E: uid=33 from=<www-data>
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/cleanup[21133]: B08131F411E: message-id=<56ab7e237d95ca7cbfc74433a419afdf@minecraft.mepi.pl>
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/qmgr[21132]: B08131F411E: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=773, nrcpt=1 (queue active)
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/pickup[21131]: B13221F4154: uid=0 from=<root>
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/cleanup[21133]: B13221F4154: message-id=<20120807152349.B13221F4154@xen-01-46-4-182-71.vps.statnet.pl>
Aug  7 17:23:49 xen-01-46-4-182-71 postfix/qmgr[21132]: B13221F4154: from=<root@xen-01-46-4-182-71.vps.statnet.pl>, size=767, nrcpt=1 (queue active)
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/smtp[21135]: 9C8131F4179: to=<Testowyfranek130@wp.pl>, relay=mx.wp.pl[212.77.101.4]:25, delay=2282, delays=2281/0.03/0.64/0.13, dsn=5.0.0, status=bounced (host mx.wp.pl[212.77.101.4] said: 554 sorry, refused mailfrom because return MX does not exist (in reply to MAIL FROM command))
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/cleanup[21133]: 8BFFA1F417D: message-id=<20120807152350.8BFFA1F417D@xen-01-46-4-182-71.vps.statnet.pl>
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/qmgr[21132]: 8BFFA1F417D: from=<>, size=2957, nrcpt=1 (queue active)
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/bounce[21145]: 9C8131F4179: sender non-delivery notification: 8BFFA1F417D
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/qmgr[21132]: 9C8131F4179: removed
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/local[21146]: 8BFFA1F417D: to=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, relay=local, delay=0.05, delays=0.03/0.01/0/0.01, dsn=2.0.0, status=sent (delivered to command: procmail -a "$EXTENSION")
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/qmgr[21132]: 8BFFA1F417D: removed
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/smtp[21137]: B08131F411E: to=<michalmpm12@gmail.com>, relay=gmail-smtp-in.l.google.com[173.194.70.27]:25, delay=2282, delays=2281/0.03/0.1/0.82, dsn=2.0.0, status=sent (250 2.0.0 OK 1344353027 dw2si23628634wib.19)
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/qmgr[21132]: B08131F411E: removed
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/local[21136]: AFDDC1F415B: to=<root@xen-01-46-4-182-71.vps.statnet.pl>, orig_to=<root>, relay=local, delay=889, delays=888/0.03/0/1, dsn=2.0.0, status=sent (delivered to command: procmail -a "$EXTENSION")
Aug  7 17:23:50 xen-01-46-4-182-71 postfix/qmgr[21132]: AFDDC1F415B: removed
Aug  7 17:23:57 xen-01-46-4-182-71 postfix/local[21138]: B13221F4154: to=<root@xen-01-46-4-182-71.vps.statnet.pl>, orig_to=<root>, relay=local, delay=2696, delays=2688/0.05/0/8, dsn=2.0.0, status=sent (delivered to command: procmail -a "$EXTENSION")
Aug  7 17:23:57 xen-01-46-4-182-71 postfix/qmgr[21132]: B13221F4154: removed
Aug  7 17:26:39 xen-01-46-4-182-71 postfix/pickup[21131]: C5AE01F4154: uid=33 from=<www-data>
Aug  7 17:26:39 xen-01-46-4-182-71 postfix/cleanup[21563]: C5AE01F4154: message-id=<38d5808546155cbcc3affbe753dbdfc0@minecraft.mepi.pl>
Aug  7 17:26:39 xen-01-46-4-182-71 postfix/qmgr[21132]: C5AE01F4154: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=773, nrcpt=1 (queue active)
Aug  7 17:26:39 xen-01-46-4-182-71 postfix/pickup[21131]: CCFB11F415B: uid=33 from=<www-data>
Aug  7 17:26:39 xen-01-46-4-182-71 postfix/cleanup[21563]: CCFB11F415B: message-id=<857fa40905338ae8ad93b42a864529a3@minecraft.mepi.pl>
Aug  7 17:26:39 xen-01-46-4-182-71 postfix/qmgr[21132]: CCFB11F415B: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=737, nrcpt=1 (queue active)
Aug  7 17:26:40 xen-01-46-4-182-71 postfix/smtp[21568]: C5AE01F4154: to=<michalmpm12@gmail.com>, relay=gmail-smtp-in.l.google.com[173.194.70.26]:25, delay=0.88, delays=0.05/0.02/0.11/0.7, dsn=2.0.0, status=sent (250 2.0.0 OK 1344353197 fo1si20204349bkc.123)
Aug  7 17:26:40 xen-01-46-4-182-71 postfix/qmgr[21132]: C5AE01F4154: removed
Aug  7 17:26:40 xen-01-46-4-182-71 postfix/smtp[21569]: CCFB11F415B: to=<testowyfrank1301@wp.pl>, relay=mx.wp.pl[212.77.101.4]:25, delay=0.75, delays=0.02/0.01/0.67/0.06, dsn=5.0.0, status=bounced (host mx.wp.pl[212.77.101.4] said: 554 sorry, refused mailfrom because return MX does not exist (in reply to MAIL FROM command))
Aug  7 17:26:40 xen-01-46-4-182-71 postfix/cleanup[21563]: B77271F4154: message-id=<20120807152640.B77271F4154@xen-01-46-4-182-71.vps.statnet.pl>
Aug  7 17:26:40 xen-01-46-4-182-71 postfix/qmgr[21132]: B77271F4154: from=<>, size=2957, nrcpt=1 (queue active)
Aug  7 17:26:40 xen-01-46-4-182-71 postfix/bounce[21570]: CCFB11F415B: sender non-delivery notification: B77271F4154
Aug  7 17:26:40 xen-01-46-4-182-71 postfix/qmgr[21132]: CCFB11F415B: removed
Aug  7 17:26:40 xen-01-46-4-182-71 postfix/local[21574]: B77271F4154: to=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, relay=local, delay=0.03, delays=0/0.02/0/0.01, dsn=2.0.0, status=sent (delivered to command: procmail -a "$EXTENSION")
Aug  7 17:26:40 xen-01-46-4-182-71 postfix/qmgr[21132]: B77271F4154: removed
Aug  7 17:27:44 xen-01-46-4-182-71 postfix/pickup[21131]: 8F3941F4154: uid=33 from=<www-data>
Aug  7 17:27:44 xen-01-46-4-182-71 postfix/cleanup[21563]: 8F3941F4154: message-id=<9d9c0b19f2fa72609ff117cd806a5fe1@minecraft.mepi.pl>
Aug  7 17:27:44 xen-01-46-4-182-71 postfix/qmgr[21132]: 8F3941F4154: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=1010, nrcpt=1 (queue active)
Aug  7 17:27:45 xen-01-46-4-182-71 postfix/smtp[21568]: 8F3941F4154: to=<testowyfrank1301@wp.pl>, relay=mx.wp.pl[212.77.101.4]:25, delay=0.72, delays=0.02/0/0.65/0.05, dsn=5.0.0, status=bounced (host mx.wp.pl[212.77.101.4] said: 554 sorry, refused mailfrom because return MX does not exist (in reply to MAIL FROM command))
Aug  7 17:27:45 xen-01-46-4-182-71 postfix/cleanup[21563]: 515A51F415B: message-id=<20120807152745.515A51F415B@xen-01-46-4-182-71.vps.statnet.pl>
Aug  7 17:27:45 xen-01-46-4-182-71 postfix/qmgr[21132]: 515A51F415B: from=<>, size=3230, nrcpt=1 (queue active)
Aug  7 17:27:45 xen-01-46-4-182-71 postfix/bounce[21570]: 8F3941F4154: sender non-delivery notification: 515A51F415B
Aug  7 17:27:45 xen-01-46-4-182-71 postfix/qmgr[21132]: 8F3941F4154: removed
Aug  7 17:27:45 xen-01-46-4-182-71 postfix/local[21574]: 515A51F415B: to=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, relay=local, delay=0.02, delays=0.01/0/0/0.01, dsn=2.0.0, status=sent (delivered to command: procmail -a "$EXTENSION")
Aug  7 17:27:45 xen-01-46-4-182-71 postfix/qmgr[21132]: 515A51F415B: removed
Aug  7 17:39:01 xen-01-46-4-182-71 postfix/pickup[21131]: 61A931F4154: uid=0 from=<root>
Aug  7 17:39:01 xen-01-46-4-182-71 postfix/cleanup[23394]: 61A931F4154: message-id=<20120807153901.61A931F4154@xen-01-46-4-182-71.vps.statnet.pl>
Aug  7 17:39:01 xen-01-46-4-182-71 postfix/qmgr[21132]: 61A931F4154: from=<root@xen-01-46-4-182-71.vps.statnet.pl>, size=767, nrcpt=1 (queue active)
Aug  7 17:39:01 xen-01-46-4-182-71 postfix/local[23396]: 61A931F4154: to=<root@xen-01-46-4-182-71.vps.statnet.pl>, orig_to=<root>, relay=local, delay=0.06, delays=0.02/0.01/0/0.04, dsn=2.0.0, status=sent (delivered to command: procmail -a "$EXTENSION")
Aug  7 17:39:01 xen-01-46-4-182-71 postfix/qmgr[21132]: 61A931F4154: removed
Aug  7 17:42:37 xen-01-46-4-182-71 postfix/master[21125]: reload -- version 2.7.1, configuration /etc/postfix
Aug  7 17:42:42 xen-01-46-4-182-71 postfix/master[21125]: terminating on signal 15
Aug  7 17:45:55 xen-01-46-4-182-71 postfix/master[24934]: daemon started -- version 2.7.1, configuration /etc/postfix
Aug  7 17:46:39 xen-01-46-4-182-71 postfix/master[24934]: terminating on signal 15
Aug  7 17:47:38 xen-01-46-4-182-71 sendmail[26028]: alias database /etc/mail/aliases rebuilt by root
Aug  7 17:47:38 xen-01-46-4-182-71 sendmail[26028]: /etc/mail/aliases: 4 aliases, longest 10 bytes, 66 bytes total
Aug  7 17:47:38 xen-01-46-4-182-71 sm-mta[26083]: starting daemon (8.14.3): SMTP+queueing@00:10:00
Aug  7 17:47:39 xen-01-46-4-182-71 sm-mta[26085]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 17:47:39 xen-01-46-4-182-71 sm-mta[26085]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=02:40:24, xdelay=00:00:01, mailer=esmtp, pri=1470731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 17:48:08 xen-01-46-4-182-71 sm-mta[26083]: restarting /usr/sbin/sendmail-mta due to signal
Aug  7 17:48:08 xen-01-46-4-182-71 sm-mta[26251]: starting daemon (8.14.3): SMTP+queueing@00:10:00
Aug  7 17:48:09 xen-01-46-4-182-71 sm-mta[26252]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 17:48:10 xen-01-46-4-182-71 sm-mta[26252]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=02:40:55, xdelay=00:00:02, mailer=esmtp, pri=1560731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 17:48:34 xen-01-46-4-182-71 sendmail[26334]: q77FmY0K026334: from=www-data, size=653, class=0, nrcpts=1, msgid=<e741b73325c298f8d702d9c6e5ac8c84@minecraft.mepi.pl>, relay=www-data@localhost
Aug  7 17:48:34 xen-01-46-4-182-71 sm-mta[26335]: q77FmYIO026335: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=760, class=0, nrcpts=1, msgid=<e741b73325c298f8d702d9c6e5ac8c84@minecraft.mepi.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 17:48:34 xen-01-46-4-182-71 sendmail[26334]: q77FmY0K026334: to=michalmpm12@gmail.com, ctladdr=www-data (33/33), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30653, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q77FmYIO026335 Message accepted for delivery)
Aug  7 17:48:34 xen-01-46-4-182-71 sendmail[26339]: q77FmYR4026339: from=www-data, size=619, class=0, nrcpts=1, msgid=<1c68f973a6fb06d51a9857a0a1cff02d@minecraft.mepi.pl>, relay=www-data@localhost
Aug  7 17:48:34 xen-01-46-4-182-71 sm-mta[26340]: q77FmYrT026340: from=<www-data@xen-01-46-4-182-71.vps.statnet.pl>, size=726, class=0, nrcpts=1, msgid=<1c68f973a6fb06d51a9857a0a1cff02d@minecraft.mepi.pl>, proto=ESMTP, daemon=MTA-v4, relay=localhost [127.0.0.1]
Aug  7 17:48:34 xen-01-46-4-182-71 sendmail[26339]: q77FmYR4026339: to=h1513114@rtrtr.com, ctladdr=www-data (33/33), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30619, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q77FmYrT026340 Message accepted for delivery)
Aug  7 17:48:34 xen-01-46-4-182-71 sm-mta[26337]: STARTTLS=client, relay=gmail-smtp-in.l.google.com., version=TLSv1/SSLv3, verify=FAIL, cipher=RC4-SHA, bits=128/128
Aug  7 17:48:35 xen-01-46-4-182-71 sm-mta[26342]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 17:48:35 xen-01-46-4-182-71 sm-mta[26342]: q77FmYrT026340: to=<h1513114@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:00:01, xdelay=00:00:01, mailer=esmtp, pri=120726, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 17:48:36 xen-01-46-4-182-71 sm-mta[26337]: q77FmYIO026335: to=<michalmpm12@gmail.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:00:02, xdelay=00:00:02, mailer=esmtp, pri=120760, relay=gmail-smtp-in.l.google.com. [173.194.70.26], dsn=2.0.0, stat=Sent (OK 1344354512 y45si22173503web.30)
Aug  7 17:49:18 xen-01-46-4-182-71 sm-mta[26251]: restarting /usr/sbin/sendmail-mta due to signal
Aug  7 17:49:18 xen-01-46-4-182-71 sm-mta[26483]: starting daemon (8.14.3): SMTP+queueing@00:10:00
Aug  7 17:49:19 xen-01-46-4-182-71 sm-mta[26484]: STARTTLS=client, relay=mail.digitalsanctuary.com., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Aug  7 17:49:19 xen-01-46-4-182-71 sm-mta[26484]: q77FmYrT026340: to=<h1513114@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=00:00:45, xdelay=00:00:01, mailer=esmtp, pri=210726, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 17:49:19 xen-01-46-4-182-71 sm-mta[26484]: q77D7FgH005037: to=<h1503005@rtrtr.com>, ctladdr=<www-data@xen-01-46-4-182-71.vps.statnet.pl> (33/33), delay=02:42:04, xdelay=00:00:00, mailer=esmtp, pri=1650731, relay=mail.digitalsanctuary.com. [174.37.94.132], dsn=4.1.8, stat=Deferred: 450 4.1.8 <www-data@xen-01-46-4-182-71.vps.statnet.pl>: Sender address rejected: Domain not found
Aug  7 17:55:09 xen-01-46-4-182-71 postfix/master[27909]: daemon started -- version 2.7.1, configuration /etc/postfix
Aug  7 17:55:23 xen-01-46-4-182-71 postfix/master[27909]: reload -- version 2.7.1, configuration /etc/postfix
Aug  7 18:09:01 xen-01-46-4-182-71 postfix/pickup[27958]: 6EC6E1F4176: uid=0 from=<root>
Aug  7 18:09:01 xen-01-46-4-182-71 postfix/cleanup[29946]: 6EC6E1F4176: message-id=<20120807160901.6EC6E1F4176@xen-01-46-4-182-71.vps.statnet.pl>
Aug  7 18:09:01 xen-01-46-4-182-71 postfix/qmgr[27959]: 6EC6E1F4176: from=<root@xen-01-46-4-182-71.vps.statnet.pl>, size=767, nrcpt=1 (queue active)
Aug  7 18:09:01 xen-01-46-4-182-71 postfix/local[29948]: 6EC6E1F4176: to=<root@xen-01-46-4-182-71.vps.statnet.pl>, orig_to=<root>, relay=local, delay=0.17, delays=0.14/0.01/0/0.02, dsn=2.0.0, status=sent (delivered to command: procmail -a "$EXTENSION")
Aug  7 18:09:01 xen-01-46-4-182-71 postfix/qmgr[27959]: 6EC6E1F4176: removed
Czego nie rozumiesz w tej linijce? Postfix nie działa bo zajmujesz jego port
On pewnie nawet nie spojrzał na to :)
Gość mpm1122
Dopiero zacząłem naukę z linuxem, a pisaliście abym dał wam logi i to zrobiłem. Proszę trochę wyrozumiałości.
