peres.pro
Problem z mysql
mam problem a mianowicie mysql przestał działać, od razu napisze że os to debian 6
po wpisaniu mysql wyskakuje:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
mysql.cnf
# The MySQL database server configuration file.
# You can copy this to one of:
# - "/etc/mysql/my.cnf" to set global options,
# - "~/.my.cnf" to set user-specific options.
# One can use all long options that the program supports.
# Run program with --help to get a list of available options and with
# --print-defaults to see which it would actually understand and use.
# For explanations see
# http://dev.mysql.com/doc/mysql/en/server-system-variables.html
# This will be passed to all mysql clients
# It has been reported that passwords should be enclosed with ticks/quotes
# escpecially if they contain "#" chars...
# Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port  = 3306
socket  = /var/run/mysqld/mysqld.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice  = 0
[mysqld]
# * Basic Settings
user  = mysql
pid-file = /var/run/mysqld/mysqld.pid
port  = 3306
basedir  = /usr
datadir  = /var/lib/mysql
tmpdir  = /tmp
# lc-message-dir is unknown to MySQL 5.1
#lc-messages-dir = /usr/share/mysql
skip-external-locking
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
#bind-address  = 127.0.0.1
# * Fine Tuning
key_buffer  = 16M
max_allowed_packet = 16M
thread_stack  = 192K
thread_cache_size	   = 8
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
myisam-recover		 = BACKUP
#max_connections	    = 100
#table_cache		    = 64
#thread_concurrency	 = 10
# * Query Cache Configuration
query_cache_limit = 1M
query_cache_size	    = 16M
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
# As of 5.1 you can enable the log at runtime!
#general_log_file	    = /var/log/mysql/mysql.log
#general_log			 = 1
# Error logging goes to syslog due to /etc/mysql/conf.d/mysqld_safe_syslog.cnf.
# Here you can see queries with especially long duration
#slow_query_log = 1
#slow_query_log_file = /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
#	   other settings you may need to change.
#server-id  = 1
#log_bin   = /var/log/mysql/mysql-bin.log
expire_logs_days = 10
max_binlog_size		 = 100M
#binlog_do_db  = include_database_name
#binlog_ignore_db = include_database_name
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer  = 16M
# * IMPORTANT: Additional settings that can override those from this file!
#   The files must end with '.cnf', otherwise they'll be ignored.
!includedir /etc/mysql/conf.d/
