m4r1usz
SMTP problem
Witam.
Mam problem z wysyłaniem maili z użyciem jakichkolwiek programów pocztowych.
Wysyłanie i odbierając maile z użyciem squirrelMail czy Roundcube wszystko działa bez problemu, ale po konfiguracji konta na outlock czy t hunderbird działa tylko pop3 a smtp już nie.
Logi
Aug 10 23:05:22 server1 postfix/postfix-script[2279]: warning: not owned by root: /etc/postfix/mysql_virtual_mailbox_limit_maps.cf Aug 10 23:05:22 server1 postfix/postfix-script[2280]: warning: not owned by root: /etc/postfix/mysql_virtual_mailbox_maps.cf Aug 10 23:05:22 server1 postfix/postfix-script[2281]: warning: not owned by root: /etc/postfix/mysql_virtual_transport_maps.cf Aug 10 23:05:22 server1 postfix/postfix-script[2282]: warning: not owned by root: /etc/postfix/post-install Aug 10 23:05:22 server1 postfix/postfix-script[2283]: warning: not owned by root: /etc/postfix/postfix-files Aug 10 23:05:22 server1 postfix/postfix-script[2284]: warning: not owned by root: /etc/postfix/postfix-script Aug 10 23:05:22 server1 postfix/postfix-script[2285]: warning: not owned by root: /etc/postfix/sasl Aug 10 23:05:22 server1 postfix/postfix-script[2286]: warning: not owned by root: /etc/postfix/virtual Aug 10 23:05:22 server1 postfix/postfix-script[2287]: warning: not owned by root: /etc/postfix/virtual.db Aug 10 23:05:22 server1 postfix/postfix-script[2289]: warning: group or other writable: /etc/postfix/./mysql_relay_domains_maps.cf Aug 10 23:05:22 server1 postfix/postfix-script[2290]: warning: group or other writable: /etc/postfix/./mysql_virtual_mailbox_maps.cf Aug 10 23:05:22 server1 postfix/postfix-script[2291]: warning: group or other writable: /etc/postfix/./mysql_virtual_mailbox_limit_maps.cf Aug 10 23:05:22 server1 postfix/postfix-script[2292]: warning: group or other writable: /etc/postfix/./mysql_virtual_transport_maps.cf Aug 10 23:05:22 server1 postfix/postfix-script[2293]: warning: group or other writable: /etc/postfix/./mysql_virtual_alias_maps.cf Aug 10 23:05:22 server1 postfix/postfix-script[2294]: warning: group or other writable: /etc/postfix/./mysql_virtual_domains_maps.cf Aug 10 23:05:22 server1 postfix/postqueue[2330]: warning: Mail system is down -- accessing queue directly Aug 10 23:06:10 server1 dovecot: auth: shadow(poczta@liner.pl,78.9.3.181): unknown user Aug 10 23:06:10 server1 dovecot: auth: passwd(poczta@liner.pl,78.9.3.181): unknown user Aug 10 23:06:10 server1 dovecot: pop3-login: Login: user=<poczta@liner.pl>, method=PLAIN, rip=78.9.3.181, lip=213.133.103.134, mpid=2359 Aug 10 23:06:10 server1 dovecot: pop3(poczta@liner.pl): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Gość patrys
Log wklejony dość kiepsko (jedna linia), mówi że masz jedynie problem z uprawnieniami dla konfiguracji...
Nadałem plikom odpowiednie uprawnienia, ale SMTP nadal niedziała.
Aug 11 11:12:48 server1 dovecot: auth: shadow(poczta@liner.pl,78.9.2.62): unknown user
Aug 11 11:12:48 server1 dovecot: auth: passwd(poczta@liner.pl,78.9.2.62): unknown user
Aug 11 11:12:48 server1 dovecot: pop3-login: Login: user=<poczta@liner.pl>, method=PLAIN, rip=78.9.2.62, lip=213.133.103.134, mpid=11253
Aug 11 11:12:48 server1 dovecot: pop3(poczta@liner.pl): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Aug 11 11:13:15 server1 dovecot: auth: shadow(poczta@liner.pl,78.9.2.62): unknown user
Aug 11 11:13:15 server1 dovecot: auth: passwd(poczta@liner.pl,78.9.2.62): unknown user
Aug 11 11:13:15 server1 dovecot: pop3-login: Login: user=<poczta@liner.pl>, method=PLAIN, rip=78.9.2.62, lip=213.133.103.134, mpid=11258
Aug 11 11:13:15 server1 dovecot: pop3(poczta@liner.pl): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Aug 11 11:16:04 server1 dovecot: auth: shadow(poczta@liner.pl,78.9.2.62): unknown user
Aug 11 11:16:04 server1 dovecot: auth: passwd(poczta@liner.pl,78.9.2.62): unknown user
Aug 11 11:16:04 server1 dovecot: pop3-login: Login: user=<poczta@liner.pl>, method=PLAIN, rip=78.9.2.62, lip=213.133.103.134, mpid=11344
Aug 11 11:16:04 server1 dovecot: pop3(poczta@liner.pl): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Aug 11 11:21:20 server1 dovecot: auth: shadow(poczta@liner.pl,78.9.2.62): unknown user
Aug 11 11:21:20 server1 dovecot: auth: passwd(poczta@liner.pl,78.9.2.62): unknown user
Aug 11 11:21:20 server1 dovecot: pop3-login: Login: user=<poczta@liner.pl>, method=PLAIN, rip=78.9.2.62, lip=213.133.103.134, mpid=11426
Aug 11 11:21:20 server1 dovecot: pop3(poczta@liner.pl): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Aug 11 11:21:51 server1 dovecot: auth: shadow(poczta@liner.pl,78.9.2.62): unknown user
Aug 11 11:21:51 server1 dovecot: auth: passwd(poczta@liner.pl,78.9.2.62): unknown user
Aug 11 11:21:51 server1 dovecot: pop3-login: Login: user=<poczta@liner.pl>, method=PLAIN, rip=78.9.2.62, lip=213.133.103.134, mpid=11433
Aug 11 11:21:51 server1 dovecot: pop3(poczta@liner.pl): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Edytowano przez m4r1usz (zobacz historię edycji)
Jakie komunikat zwraca program pocztowy ?
Przez jaki port próbujesz wysłać pocztę ? Jeżeli 25 to zmień na 587.
Pokaż konfigurację postfixa.
Pokaż logi postfixa.
Przy porcie 25 program zwracał komunikat
Wyślij testową wiadomość e-mail: Program Outlook nie może połączyć się z serwerem poczty wychodzącej (SMTP). Jeśli komunikat ten będzie nadal wyświetlany, skontaktuj się z administratorem serwera lub usługodawcą internetowym (ISP).
Przy porcie 587 zwraca
Wyślij testową wiadomość e-mail: Wystąpił nieznany błąd, kod błędu: 0x80040607
main.cf
# See /usr/share/postfix/main.cf.dist for a commented, more complete v
# Debian specific:  Specifying a file name will cause the first
# line of that file to be used as the name.  The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
biff = no
hosts = 127.0.0.1
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=no
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
smtpd_sasl_auth_enable = yes
smtpd_sasl2_auth_enable = yes
smtpd_sasl_security_options = noanonymous
smtpd_sasl_local_domain =
broken_sasl_auth_clients = yes
smtpd_sasl_authenticated_header = yes
smtpd_recipient_restrictions = permit_sasl_authenticated, reject_unauth_destination, permit_mynetworks
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unknown_client
#smtpd_sasl_auth_enable = yes
#broken_sasl_auth_clients = yes
#smtpd_sasl_security_options = noanonymous
#smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
# See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
# information on enabling SSL in the smtp client.
myhostname = localhost
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = webplace, localhost.localdomain, localhost
relayhost =
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
local_recipient_maps = unix:passwd.byname $alias_maps
relay_domains = mysql:/etc/postfix/mysql_relay_domains_maps.cf
virtual_alias_maps  	= mysql:/etc/postfix/mysql_virtual_alias_maps.cf
virtual_uid_maps    	= static:8
virtual_gid_maps    	= static:8
virtual_mailbox_base	= /var/mail/vmail
virtual_mailbox_domains = mysql:/etc/postfix/mysql_virtual_domains_maps.cf
virtual_mailbox_limit   = 51200000
virtual_mailbox_maps	= mysql:/etc/postfix/mysql_virtual_mailbox_maps.cf
virtual_minimum_uid 	= 8
#virtual_transport = sasl2
mailbox_transport = virtual
maildrop_destination_recipient_limit = 1
# Transport map
transport_maps  = mysql:/etc/postfix/mysql_virtual_transport_maps.cf
vacation_destination_recipient_limit = 1
# Additional for quota support
virtual_create_maildirsize 	= yes
virtual_mailbox_extended   	= yes
virtual_mailbox_limit_maps 	= mysql:/etc/postfix/mysql_virtual_mailbox_limit_maps.cf
virtual_mailbox_limit_override = yes
virtual_maildir_limit_message  = Przepraszamy, wyczerpales swoj limit miejsca na dysku.
#smtpd_sasl_local_domain = webplace.com.pl
#smtpd_sasl_path             	= smptd
#smtpd_sasl_authenticated_header = yes
#smtpd_recipient_restrictions	=  permit_mynetworks,permit_sasl_authenticated,reject_non_fqdn_hostname,reject_non_fqdn_sender,reject_non_fqdn_recipient,reject_unauth_destination,reject_unauth_pipelining,reject_invalid_hostname,reject_rbl_client opm.blitzed.org,reject_rbl_client list.dsbl.org,reject_rbl_client bl.spamcop.net,reject_rbl_client sbl-xbl.spamhaus.org
smtpd_banner =
mail.er
Aug 10 22:55:23 server1 postfix/master[941]: fatal: bind 0.0.0.0 port 25: Address already in use
Gość patrys
mail.er
pokaz wynik:
netstat -ntpl | grep -e :25 -e :587
server1:~# netstat -ntpl | grep -e :25 -e :587
tcp    	0  	0 0.0.0.0:587         	0.0.0.0:*           	LISTEN  	2905/exim
tcp    	0  	0 0.0.0.0:25          	0.0.0.0:*           	LISTEN  	2905/exim
tcp6   	0  	0 :::587              	:::*                	LISTEN  	2905/exim
tcp6   	0  	0 :::25               	:::*                	LISTEN  	2905/exim
Gość patrys
Świetnie ;) Zostaje się zdecydować z którego MTA chce się korzystać...
Dziwiło już jak wklejałem wynik:)
Zaraz odinstaluje exima i wkleję ewentualne logi, ale pewnie to jest rozwiązanie problemu.
Ok na serwerze nasłuchuje postfix, ale smtp dalej nie trybi.
Logi
Aug 11 23:53:14 server1 postfix/master[20743]: warning: process /usr/lib/postfix/qmgr pid 20884 exit status 1
Aug 11 23:53:14 server1 postfix/master[20743]: warning: /usr/lib/postfix/qmgr: bad command startup -- throttling
Aug 11 23:54:14 server1 postfix/cleanup[20929]: fatal: dict_open: unsupported dictionary type: mysql (/usr/lib/postfix/dict_mysql.so not found.  Is the postfix-mysql package installed?)
Aug 11 23:54:14 server1 postfix/qmgr[20930]: fatal: dict_open: unsupported dictionary type: mysql (/usr/lib/postfix/dict_mysql.so not found.  Is the postfix-mysql package installed?)
Aug 11 23:54:15 server1 postfix/master[20743]: warning: process /usr/lib/postfix/cleanup pid 20929 exit status 1
Aug 11 23:54:15 server1 postfix/master[20743]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
Aug 11 23:54:15 server1 postfix/master[20743]: warning: process /usr/lib/postfix/qmgr pid 20930 exit status 1
Aug 11 23:54:15 server1 postfix/master[20743]: warning: /usr/lib/postfix/qmgr: bad command startup -- throttling
Aug 11 23:55:15 server1 postfix/qmgr[21056]: fatal: dict_open: unsupported dictionary type: mysql (/usr/lib/postfix/dict_mysql.so not found.  Is the postfix-mysql package installed?)
Aug 11 23:55:15 server1 postfix/cleanup[21055]: fatal: dict_open: unsupported dictionary type: mysql (/usr/lib/postfix/dict_mysql.so not found.  Is the postfix-mysql package installed?)
Aug 11 23:55:16 server1 postfix/master[20743]: warning: process /usr/lib/postfix/qmgr pid 21056 exit status 1
Aug 11 23:55:16 server1 postfix/master[20743]: warning: /usr/lib/postfix/qmgr: bad command startup -- throttling
Aug 11 23:55:16 server1 postfix/master[20743]: warning: process /usr/lib/postfix/cleanup pid 21055 exit status 1
Aug 11 23:55:16 server1 postfix/master[20743]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
Aug 11 23:56:16 server1 postfix/cleanup[21071]: fatal: dict_open: unsupported dictionary type: mysql (/usr/lib/postfix/dict_mysql.so not found.  Is the postfix-mysql package installed?)
Aug 11 23:56:16 server1 postfix/qmgr[21070]: fatal: dict_open: unsupported dictionary type: mysql (/usr/lib/postfix/dict_mysql.so not found.  Is the postfix-mysql package installed?)
Aug 11 23:56:17 server1 postfix/master[20743]: warning: process /usr/lib/postfix/cleanup pid 21071 exit status 1
Aug 11 23:56:17 server1 postfix/master[20743]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
Aug 11 23:56:17 server1 postfix/master[20743]: warning: process /usr/lib/postfix/qmgr pid 21070 exit status 1
Aug 11 23:56:17 server1 postfix/master[20743]: warning: /usr/lib/postfix/qmgr: bad command startup -- throttling
Zainstalowane
Aug 12 00:17:56 server1 postfix/cleanup[22011]: B5A8118870B: message-id=<67b72da544f3deec1aca40af8e09e2a9@domnocy.pl>
Aug 12 00:17:56 server1 postfix/cleanup[22011]: warning: B5A8118870B: virtual_alias_maps map lookup problem for dominika@gg.pl
Aug 12 00:17:57 server1 postfix/trivial-rewrite[22048]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
Aug 12 00:17:57 server1 postfix/trivial-rewrite[22048]: fatal: mysql:/etc/postfix/mysql_virtual_alias_maps.cf(0,lock|fold_fix): table lookup problem
Aug 12 00:17:57 server1 postfix/pickup[21269]: BEC7118870B: uid=5004 from=<domnocy@domnocy.pl>
Aug 12 00:17:57 server1 postfix/cleanup[22012]: BEC7118870B: message-id=<89cbb6be62fd8c3bef0dfe53f21732ea@domnocy.pl>
Aug 12 00:17:57 server1 postfix/cleanup[22012]: warning: BEC7118870B: virtual_alias_maps map lookup problem for angie911@buziaczek.pl
Aug 12 00:17:58 server1 postfix/qmgr[22010]: warning: problem talking to service rewrite: Success
Aug 12 00:17:58 server1 postfix/master[20743]: warning: process /usr/lib/postfix/trivial-rewrite pid 22048 exit status 1
Aug 12 00:17:58 server1 postfix/pickup[21269]: C534D18870B: uid=5004 from=<domnocy@domnocy.pl>
Aug 12 00:17:58 server1 postfix/cleanup[22011]: C534D18870B: message-id=<3e6c7b563f6027a0ef8165b27a7690a8@domnocy.pl>
Aug 12 00:17:58 server1 postfix/cleanup[22011]: warning: C534D18870B: virtual_alias_maps map lookup problem for metka013@o2.pl
Aug 12 00:17:59 server1 postfix/trivial-rewrite[22052]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
Aug 12 00:17:59 server1 postfix/trivial-rewrite[22052]: fatal: mysql:/etc/postfix/mysql_virtual_alias_maps.cf(0,lock|fold_fix): table lookup problem
Aug 12 00:17:59 server1 postfix/pickup[21269]: C5FCB18870B: uid=5004 from=<domnocy@domnocy.pl>
Aug 12 00:18:00 server1 postfix/cleanup[22012]: warning: problem talking to service rewrite: Connection reset by peer
Aug 12 00:18:00 server1 postfix/qmgr[22010]: warning: problem talking to service rewrite: Success
Aug 12 00:18:00 server1 postfix/master[20743]: warning: process /usr/lib/postfix/trivial-rewrite pid 22052 exit status 1
Aug 12 00:18:01 server1 postfix/trivial-rewrite[22060]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
Aug 12 00:18:01 server1 postfix/trivial-rewrite[22060]: fatal: mysql:/etc/postfix/mysql_virtual_alias_maps.cf(0,lock|fold_fix): table lookup problem
Oznacza to, że ustawiłeś Postfiksa, co by informacje o kontach mailowych zasysał z bazy danych MySQL.
Lecz zapomniałeś najwidoczniej owej bazy danych stworzyć (i silnika pewnie też nie masz zainstalowanego) ;)
Wskazówka: Cóż to za dziwna konstrukcja np. tego wpisu:
Uzupełniłem dane do bazy danych, jednak smtp dalej nie działa.
Aug 16 17:13:15 server1 postfix/master[20743]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
Aug 16 17:13:21 server1 postfix/trivial-rewrite[1306]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
Aug 16 17:13:21 server1 postfix/trivial-rewrite[1306]: fatal: mysql:/etc/postfix/mysql_virtual_alias_maps.cf(0,lock|fold_fix): table lookup problem
Aug 16 17:13:22 server1 postfix/qmgr[1002]: warning: problem talking to service rewrite: Success
Aug 16 17:13:22 server1 postfix/cleanup[610]: warning: problem talking to service rewrite: Connection reset by peer
Aug 16 17:13:22 server1 postfix/master[20743]: warning: process /usr/lib/postfix/trivial-rewrite pid 1306 exit status 1
Aug 16 17:13:22 server1 postfix/master[20743]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Aug 16 17:14:11 server1 dovecot: auth: shadow(poczta@liner.pl,78.8.102.82): unknown user
Aug 16 17:14:11 server1 dovecot: auth: passwd(poczta@liner.pl,78.8.102.82): unknown user
Aug 16 17:14:11 server1 dovecot: pop3-login: Login: user=<poczta@liner.pl>, method=PLAIN, rip=78.8.102.82, lip=213.133.103.134, mpid=1316
Aug 16 17:14:12 server1 dovecot: pop3(poczta@liner.pl): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Aug 16 17:14:15 server1 postfix/smtpd[1317]: fatal: bad string length 0 < 1: smtpd_banner =
Aug 16 17:14:16 server1 postfix/master[20743]: warning: process /usr/lib/postfix/smtpd pid 1317 exit status 1
Aug 16 17:14:16 server1 postfix/master[20743]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
Aug 16 17:14:22 server1 postfix/trivial-rewrite[1318]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
Aug 16 17:14:22 server1 postfix/trivial-rewrite[1318]: fatal: mysql:/etc/postfix/mysql_virtual_alias_maps.cf(0,lock|fold_fix): table lookup problem
Aug 16 17:14:23 server1 postfix/qmgr[1002]: warning: problem talking to service rewrite: Interrupted system call
Aug 16 17:14:23 server1 postfix/cleanup[610]: warning: problem talking to service rewrite: Connection reset by peer
Aug 16 17:14:23 server1 postfix/master[20743]: warning: process /usr/lib/postfix/trivial-rewrite pid 1318 exit status 1
Aug 16 17:14:23 server1 postfix/master[20743]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Czy ty potrafisz czytać to co do ciebie konsola pluje ?
Bazę danych mam utworzoną i przez phpmy admina się łącze.
w /tmp też jest ok
server1:/tmp# ls
mysql.sock
sess_1c37108fd7e12b31a238592fd5437124d042ac0c
Mysql na serwerze działa
server1:/var/run/mysqld# ls -l
razem 4,0K
-rw-rw---- 1 mysql mysql 6 sie 10 21:08 mysqld.pid
srwxrwxrwx 1 mysql mysql 0 sie 10 21:08 mysqld.sock
Wpisałeś w pliki odpowiadające za komunikacje z MySQL ( /etc/postfix-* ) złe połączenie, popraw socket albo zmień na tcp...
ps. jak już kopiujesz jakieś howto to z głową.
Ten problem już mam rozwiązany, lecz dalej nie działa jak powinno.
Aug 17 13:51:55 server1 postfix/scache[31112]: statistics: start interval Aug 17 13:48:35
Aug 17 13:51:55 server1 postfix/scache[31112]: statistics: domain lookup hits=0 miss=1 success=0%
Aug 17 13:51:55 server1 postfix/scache[31112]: statistics: address lookup hits=0 miss=2 success=0%
Aug 17 13:51:55 server1 postfix/scache[31112]: statistics: max simultaneous domains=1 addresses=2 connection=2
Aug 17 13:53:05 server1 dovecot: auth: shadow(poczta@liner.pl,78.9.2.231): unknown user
Aug 17 13:53:05 server1 dovecot: auth: passwd(poczta@liner.pl,78.9.2.231): unknown user
Aug 17 13:53:05 server1 dovecot: pop3-login: Login: user=<poczta@liner.pl>, method=PLAIN, rip=78.9.2.231, lip=213.133.103.134, mpid=31212
Aug 17 13:53:05 server1 dovecot: pop3(poczta@liner.pl): Error: user poczta@liner.pl: Initialization failed: Initializing mail storage from mail_location setting failed: mkdir(/home/vmail/liner.pl/poczta/Maildir) failed: Permission denied (euid=5012(liner) egid=8(mail) missing +w perm: /home, euid is not dir owner)
Aug 17 13:53:05 server1 dovecot: pop3(poczta@liner.pl): Error: Invalid user settings. Refer to server log for more information.
Nie rozumiem tego wpisu. Ja mam ścieżkę do maili /home/user/Maildir
To jest komunikat od Dovecota, a nie Postfiksa.
Może owy katalog w konfiguracji obu tych daemonów jest inny?
Ty ewidentnie przeklepałeś manuala z google nawet nie próbujac go czytać a co dopiero zrozumieć.
