omajgat
Problem z postfixem?
Witam, skonfigurowałem swoj pierwszy server wedle poradnika: http://www.nfire.eu/...s&article_id=37 ((Postfix + Dovecot + SASL + TLS/SSL + RoundCube Webmail)).
Wszelkie testu przebiegały pomyslnie, wysyla i odbiera maile, ale niestety z gmail.com nie odbiera, błąd:
Delivered-To: bojem.siem@gmail.com
Received: by 10.216.56.67 with SMTP id l45cs185795wec;
Sun, 31 Jan 2010 09:37:35 -0800 (PST)
Received: by 10.216.172.203 with SMTP id t53mr2236353wel.56.1264959455420;
MIME-Version: 1.0
Return-Path: <>
Received: by 10.216.172.203 with SMTP id t53mr2635375wel.56; Sun, 31 Jan 2010
From: Mail Delivery Subsystem <mailer-daemon@googlemail.com>
X-Failed-Recipients: testmail@.....pl
Subject: Delivery Status Notification (Failure)
Message-ID: <0016367fa45cfee0a3047e79526f@google.com>
Date: Sun, 31 Jan 2010 17:37:35 +0000
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: quoted-printable
Delivery to the following recipient failed permanently:
testmail@.....pl
Technical details of permanent failure:=20
Google tried to deliver your message, but it was rejected by the recipient =
domain. We recommend contacting the other email provider for further inform=
ation about the cause of this error. The error that the other server return=
ed was: 530 530 5.7.0 Must issue a STARTTLS command first (state 13).
----- Original message -----
MIME-Version: 1.0
Received: by 10.216.172.203 with SMTP id t53mr2236332wel.56.1264959453954;=
=20
Sun, 31 Jan 2010 09:37:33 -0800 (PST)
Date: Sun, 31 Jan 2010 17:37:33 +0000
Message-ID: <b2d57fd81001310937s41041cf6x81e6a396e753fd66@mail.gmail.com>
Subject: test
To: testmail@....pl
Content-Type: multipart/alternative; boundary=3D0016367fa45ce88560047e79524=
1
thgf
Bede wdzieczny za pomoc.
Problemem jest: "530 5.7.0 Must issue a STARTTLS command first (state 13)"
Poszukaj tego w google, sporo wyników jest.
Wygląda na to, iż Twój Postfix wymusza użycie TLS w trakcie połączenia SMTP.
Żaden MX, który tego nie obsługuje, w tym wypadku GMail
( brawa dla Google przy okazji! ), nie będzie mógł dostarczyć poczty.
A dokładniej:
Aby serwer oferował połączenie szyfrowane lecz zezwalał także na połączenia nieszyfrowane musimy zmienić konfigurację SMTP i POP3/IMAP.
Dla SMTP w pliku /etc/postfix/main.cf zmieniamy:
smtpd_tls_security_level = may
smtpd_tls_auth_only = no
dla POP3/IMAP w pliku /etc/dovecot/dovecot.conf zmieniamy:
protocols = pop3 pop3s imap imaps
