ivaho
Problem ze strona
moja domena to money-monitor.com
jak mozna zauwazyc strona nie dziala.
Napisalem do providera odpowiedzial mi ze z hostingiem wszystko jest ok.
Napisal mi ze prawdopodobnie to jest problem po stronie rejestratora domeny.
Jest nim ta firma:
http://www.gold-domain.com
Obecnie nie moge sie zalogowac do cpanela, gdy probuje wyslac maila do admina dostaje zwrotke
Mail Delivery System <Mailer-Daemon@james.891213.com>
Mail delivery failed: returning message to sender
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
pipe to | /home/jeff/www/cgi-bin/automail.pl
generated by support@gold-domain.com
local delivery failed
The following text was generated during the delivery attempt:
------ pipe to | /home/jeff/www/cgi-bin/automail.pl
generated by support@gold-domain.com ------
Died at /home/jeff/www/cgi-bin/automail.pl line 302, <STDIN> line 28.
------ This is a copy of the message, including all the headers. ------
Return-path: <styler@epf.pl>
Received: from [195.116.221.99] (port=39863 helo=mail133.pi.net.pl)
by james.891213.com with smtp (Exim 4.52)
id 1EKaku-0002bd-Rl
for support@gold-domain.com; Wed, 28 Sep 2005 20:09:49 +0800
Received: (qmail 15348 invoked from network); 28 Sep 2005 12:09:48 -0000
Received: from unknown (HELO PC116878316169) (styler@217.116.100.252)
by 195.205.153.133 with SMTP; 28 Sep 2005 12:09:47 -0000
Date: Wed, 28 Sep 2005 14:09:29 +0200
X-Mailer: The Bat! (v3.60.07) Professional
Reply-To: styler@epf.pl
X-Priority: 3 (Normal)
Message-ID: <1013532713.20050928140929@epf.pl>
To: support@gold-domain.com
Subject: test
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Gdy probuje wyslac wiadomosc z innej poczty prolem sie powtarza.
Czy istnieje mozliwosc sprawdzenia czyja to wina ze moja strona nie dziala?
Dlaczego nastepuje zwrotka?
Dziekuje i pozdrawiam
No to Ci dziwnie odpisał. Rola rejestratora domen kończy się z chwilą zarejestrowania domeny. Jeżeli w domenie masz poprawnie wpisane nazwy serwerów DNS to reszta należy do providera.
Masz stronę na irańskim serwerze?
P.S. Kiedy zmieniałeś w domenie serwery DNS?
na kanadyjskim, udalo mi sie znalesc support do domeny, http://www.gold-domain.com/support/ zobaczymy co odpowiedza.
Provider wskazal mi adres do mojego konta na serwerze (~xxx) gdzie rzeczywiscie moja strona dziala. Strona nie dziala mi od wczoraj wieczora.
Wczesniej nie mialem problemow z tym hostingiem.
Sprawdzilem w whois ze name serwery sa dobrze wpisane. :/
Jakis miesiac temu
Wysłany Czw Wrz 29, 2005 7:38 am:
Hm, dostalem odpowiedz od rejestratora domeny:
It appears money-monitor.com is in Registrar-Hold status.  I'm checking with the registrar and see what's going on
there.  Thanks for your patience.
Co o tym sadzicie? Jaki moze byc powod?
No własnie, teraz w Whois zauważyłem, że masz zablokowaną domenę przez rejestratora. Domenę masz zarejestrowana w enom.com więc napisz do nich.
z enom.com moga sie kontaktowac tylko resellerzy w sprawie domen, a ja moge sie kontaktowac ze swoim resellerem.
Znalazlem jednak jakis adres email w whois enom.com i wyslalem, zobaczymy z jakim skutkiem.
Dla mnie to jest bez sensu, wlasciwie kazda domena moze byc zablokowana, przeciez ja nie przentuje tresci erotycznych itp, i tak wogole reklamacje w temacie tresci strony sklada sie do hostingu, pomyslcie ze kazda wasza strona moze byc w ten sposob zablokowana, bez ostrzezenia, bez wyjasnienia, bez rekompensaty za stracone pieniadze (platne bannery,google ads), za stracona pozycje w wyszukiwarkach. Dla mnie ta cala sytuacja jest niewiarygodna. Ja rozumiem problemy z hostingiem, ale z domena, ktora zostala oplacona prawidlowo???
Zalamka...
Barzo dziwna sprawa.
Ale ja tesz mam problem z jedna domeną.
Nie moge przepisac na swóje prywatne dns.
Tak to już bywa
