Gość Aktualka Zgłoś post Napisano Wrzesień 7, 2009 Witajcie Mam taki dziwny problem z debianem 5.0 Nie jestem jego zwolennikiem ale niestety musze go miec. debian:/var/lib/dpkg/info# apt-get updateHit http://ftp.pl.debian.org lenny Release.gpg Ign http://ftp.pl.debian.org lenny/main Translation-en_US Hit http://ftp.pl.debian.org lenny Release Hit http://volatile.debian.org lenny/volatile Release.gpg Ign http://volatile.debian.org lenny/volatile/main Translation-en_US Ign http://ftp.pl.debian.org lenny/main Packages/DiffIndex Hit http://volatile.debian.org lenny/volatile Release Ign http://ftp.pl.debian.org lenny/main Sources/DiffIndex Hit http://ftp.pl.debian.org lenny/main Packages Hit http://security.debian.org lenny/updates Release.gpg Hit http://ftp.pl.debian.org lenny/main Sources Ign http://security.debian.org lenny/updates/main Translation-en_US Ign http://volatile.debian.org lenny/volatile/main Packages/DiffIndex Hit http://security.debian.org lenny/updates Release Ign http://volatile.debian.org lenny/volatile/main Sources/DiffIndex Ign http://security.debian.org lenny/updates/main Packages/DiffIndex Hit http://volatile.debian.org lenny/volatile/main Packages Ign http://security.debian.org lenny/updates/main Sources/DiffIndex Hit http://volatile.debian.org lenny/volatile/main Sources Hit http://security.debian.org lenny/updates/main Packages Hit http://security.debian.org lenny/updates/main Sources Reading package lists... Done debian:/var/lib/dpkg/info# apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0B of additional disk space will be used. Do you want to continue [Y/n]? y Setting up linux-image-2.6.26-2-amd64 (2.6.26-19) ... Running depmod. Running mkinitramfs-kpkg. Not updating initrd symbolic links since we are being updated/reinstalled (2.6.26-17lenny2 was configured last, according to dpkg) Failed to symbolic-link boot/vmlinuz-2.6.26-2-amd64 to vmlinuz. dpkg: error processing linux-image-2.6.26-2-amd64 (--configure): subprocess post-installation script returned error exit status 17 Errors were encountered while processing: linux-image-2.6.26-2-amd64 E: Sub-process /usr/bin/dpkg returned an error code (1) Powiedzcie jaki tu moze byc problem ? Jakis pakiet wadzi ?Nic nie moge usunac ani nic nie moge zainstalowac Udostępnij ten post Link to postu Udostępnij na innych stronach
Malas 0 Zgłoś post Napisano Wrzesień 7, 2009 WitajcieMam taki dziwny problem z debianem 5.0 Nie jestem jego zwolennikiem ale niestety musze go miec. Powiedzcie jaki tu moze byc problem ? Jakis pakiet wadzi ?Nic nie moge usunac ani nic nie moge zainstalowac http://www.linuxquestions.org/questions/de...-code-1-171107/ ehh 1 strona z googli po wpisaniu komunikatu błędu. Udostępnij ten post Link to postu Udostępnij na innych stronach
Gość Aktualka Zgłoś post Napisano Wrzesień 7, 2009 apt-get remove linux-image-2.6.26-2-amd64 :) tak zrobilem lol no i dziala Nie wiem czy dobrze czy nie. ok bedzie ? Udostępnij ten post Link to postu Udostępnij na innych stronach
