lukas17 0 Zgłoś post Napisano Czerwiec 21, 2009 mam problem z instalacja embperl pod windows: C:\Embperl-2.3.0>perl Makefile.PL Running on Win 32 Build with support for Apache mod_perl?(y/n) [y] Use /Apache as Apache source(y/n) [y] Will use C:/Apache for Apache Headers Apache Version Server version: Apache/1.3.31 (Win32) + Load dynamic module mod_perl.c (C:\Apache\modules\mod_perl.so) Test start C:\Apache\Apache.exe Test httpd will listen on port 8531 Found mod_perl Version 1.2901 Found LWP::UserAgent Version 5.826 Found HTML::HeadParser Version 3.60 Found Apache::Session Version 1.81 Found Apache::SessionX Version 2.01 Found File::Spec Version 3.29 Found CGI Version 3.43 Enter path of the directory where you have extracted libxml2 and libxslt or sing le dot for not using libxml [C:\lib] libxslt and libxml2 found under C:\lib/libxslt-1.1.0.win32/lib and C:\lib/libxml 2-2.6.2+.win32/lib Xalan is currently not supported on Win32 Note (probably harmless): No library found for oldnames.lib Note (probably harmless): No library found for kernel32.lib Note (probably harmless): No library found for user32.lib (...) Note (probably harmless): No library found for odbc32.lib Note (probably harmless): No library found for odbccp32.lib Note (probably harmless): No library found for msvcrt.lib Writing Makefile for Embperl::Thread Writing Makefile for Embperl Writing Makefile for WrapXS Writing Makefile for Embperl C:\Embperl-2.3.0>nmake Microsoft ® Program Maintenance Utility Version 1.50 Copyright © Microsoft Corp 1988-94. All rights reserved. nmake -f Makefile all -nologo nmake -f Makefile all -nologo nmake -f Makefile all -nologo cl -c -IC:/Embperl-2.3.0 -I. -I"C:/Apache/include" -I"C:/Apache/regex" -I"C:/Apache/os/win32" -I"C:\lib\libxslt-1.1.0.win32\include" -I"C:\lib\libxml2- 2.6.2+.win32\include" -I"C:\lib\iconv-1.9.1.win32\include" -IC:/Embperl-2.3.0/xs -nologo -GF -W3 -MD -Zi -DNDEBUG -O1 -DWIN32 -D_CONSOLE -DNO_STRICT -DHAVE_DES _FCRYPT -DNO_HASH_SEED -DUSE_SITECUSTOMIZE -DPRIVLIB_LAST_IN_INC -DPERL_IMPLICIT _CONTEXT -DPERL_IMPLICIT_SYS -DUSE_PERLIO -DPERL_MSVCRT_READFIX -MD -Zi -DNDEBUG -O1 -DVERSION=\"2.3.0\" -DXS_VERSION=\"2.3.0\" "-IC:\Perl\lib\CORE" -DAPA CHE -D_INC_MALLOC -D_INC_SIGNAL -D_WINSOCK2API_ -D_MSWSOCK_ -D_WINDOWS -DMULT IPLICITY -DEP2 -DLIBXSLT App.c fatal error C1510: Cannot load language resource clui.dll. NMAKE : fatal error U1077: 'C:\WINDOWS\system32\cmd.exe' : return code '0x4' Stop. NMAKE : fatal error U1077: 'C:\WINDOWS\system32\cmd.exe' : return code '0x2' Stop. NMAKE : fatal error U1077: 'C:\WINDOWS\system32\cmd.exe' : return code '0x2' Stop. NMAKE : fatal error U1077: 'C:\WINDOWS\system32\cmd.exe' : return code '0x2' Stop. Udostępnij ten post Link to postu Udostępnij na innych stronach
