Krystian
Problem z apt-get
Mam mały problem z apt-getem, a mianowicie wydając polecenie: apt-get update
otrzymuje:
KDZ001:~# apt-get update
Err http://security.debian.org etch/updates Release.gpg
 Temporary failure resolving 'security.debian.org'
Err http://ftp2.de.debian.org etch Release.gpg
 Temporary failure resolving 'ftp2.de.debian.org'
Failed to fetch http://ftp2.de.debian.org/debian/dists/etch/Release.gpg  Temporary failure resolving 'ftp2.de.debian.org'
Failed to fetch http://security.debian.org/dists/etch/updates/Release.gpg  Temporary failure resolving 'security.debian.org'
Reading package lists... Done
W: Couldn't stat source package list http://ftp2.de.debian.org etch/main Packages (/var/lib/apt/lists/ftp2.de.debian.org_debian_dists_etch_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://security.debian.org etch/updates/main Packages (/var/lib/apt/lists/security.debian.org_dists_etch_updates_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://security.debian.org etch/updates/contrib Packages (/var/lib/apt/lists/security.debian.org_dists_etch_updates_contrib_binary-i386_Packages) - stat (2 No such file or directory)
W: You may want to run apt-get update to correct these problems
E: Some index files failed to download, they have been ignored, or old ones used instead.
KDZ001:~#
Mój source list wygląda tak:
# deb cdrom:[Debian GNU/Linux 4.0 r0 _Etch_ - Official i386 NETINST Binary-1 20070407-11:29]/ etch contrib main
#deb cdrom:[Debian GNU/Linux 4.0 r0 _Etch_ - Official i386 NETINST Binary-1 20070407-11:29]/ etch contrib main
deb http://ftp2.de.debian.org/debian/ etch main
deb-src http://ftp2.de.debian.org/debian/ etch main
deb http://security.debian.org/ etch/updates main contrib
deb-src http://security.debian.org/ etch/updates main contrib
Potrafi ktoś mi pomóc?
W komunikacie pisze jak byk:
Masz problem z odwzrorowaniem nazwy domeny.
Pokaz wynik cat /etc/resolv.conf. Wyglada jakbys nie mial po prostu ustawionych nameserverow. Czy mozesz pobrac cokolwiek np. via wget?
resolv.conf
KDZ001:~# cat /etc/resolv.conf
search domena.pl
nameserver 127.0.0.1
nameserver 194.204.152.34
No właśnie chyba tutaj coś popsułem :)
Nie mogę nic pobrać. Jak powinno wyglądać resolv.conf?
takie ustawienie znalazłem w jakimś manualu, widocznie jest złe :/
Muszę tutaj podać drugi nameserver który mam od leaseweb?
Jak powinno wyglądać resolv.conf to powie Ci Twój dostawca internetu gdyż zdaża się, iż niektórzy blokują możliwość korzystania z DNS'ów zewnętrzych operatorów.
Ustawiłem tak:
nameserver 62.212.76.50
"Our secondary nameserver IP is: 62.212.76.50 (ns7.leaseweb.net)"
Należy teraz coś zresetować?
Nie, powinno dzialac od reki. Dodaj sobie tez nscache leaseweb do resolva - 85.17.96.69.
