MiSi3kK
Problem Z Apachem
Od 2 dni serwer zaczyna niesamowicie zamulać. Wygląda to na błąd apache. Od dłuższego czasu nie wprowadzałem żadnych zmian, więc nie wiem w czym problem. Do error_log jest ciągle coś dopisywane [a nawet cała masa]Praktycznie powtarzają się tylko takie wpisy:
Destroying config 0x866e470
Destroying config 0x866dfd8
Destroying config 0x866df00
Destroying config 0x866b948
Creating new config (0x8667938) for merge_php_config
Merge dir (0x8329718)+(0x833e340)=(0x8667938)
Creating new config (0x866df00) for /var/www/vhosts/domena.pl/httpdocs/Getting display_errors=1 for 0x866df00 (0)
Creating new config (0x866dfd8) for merge_php_config
Merge dir (0x8667938)+(0x866df00)=(0x866dfd8)ADDING/OVERWRITING engine (4 vs. -1)ADDING/OVERWRITING safe_mode (4 vs. -1)ADDING/OVERWRITING open_basedir (4 vs. -1)
Creating new config (0x866e470) for merge_php_config
Merge dir (0x80fbb40)+(0x866dfd8)=(0x866e470)APPLYING (display_errors)(1)
APPLYING (engine)(1)APPLYING (safe_mode)(0)
APPLYING (open_basedir)(/var/www/vhosts/domena.pl/httpdocs:/tmp)
Destroying config 0x8667938
Creating new config (0x8669708) for merge_php_config
Merge dir (0x80fbb40)+(0x83327b8)=(0x8669708)
APPLYING (engine)(1)APPLYING (magic_quotes_gpc)(0)
APPLYING (open_basedir)(/usr/share/psa-horde:/etc/psa-horde:/etc/psa:/tmp:/var/tmp:/var/log/psa-horde:/usr/share/doc)
APPLYING (include_path)(/usr/share/psa-horde:/usr/share/psa-horde/pear:.)
Destroying config 0x8669708
Creating new config (0x866b8a0) for merge_php_config
Merge dir (0x8329718)+(0x837bb40)=(0x866b8a0)
Creating new config (0x866bbc8) for merge_php_config
sorry, jeden temat do usunięcia, wysłało 2 razy
Z paczki [pod plesk]
Apache/2.0.53 (Linux/SUSE)
